Home » Language IDEs » CDT » Tool Settings properties tab not available
Tool Settings properties tab not available [message #834992] Mon, 02 April 2012 12:54 Go to next message
Andrew Wiles is currently offline Andrew Wiles
hi all,
i find that the Tool Settings tab,Build Step tab and Build Artifact tab are available only if the "Generate Makefiles automatically" option(under C/C++ build-->builder settings tab) is checked. is it by design? what's the rationale?
thanks
Re: Tool Settings properties tab not available [message #835537 is a reply to message #834992] Tue, 03 April 2012 07:19 Go to previous message
Axel Mueller is currently offline Axel Mueller
That is by design. If you disable "Generate Makefiles automatically" you must provide your own makefile for the build process. Thus, there is no need to show the Tool Settings tab for the compiler.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:Problems occured while refreshing local changes
Next Topic:Reuse CDT editor in custom project
Current Time: Wed May 22 17:45:23 EDT 2013
Powered by FUDForum. Page generated in 0.01423 seconds
