Home » Eclipse Projects » Virgo » Unable to find Library ( .libd ) file Error
Unable to find Library ( .libd ) file Error [message #835023] Mon, 02 April 2012 13:48 Go to next message
Obiwan Kenobi is currently offline Obiwan Kenobi
I am running virgo tomcat server 3.0.1 version.I have deployed bundle which has manifest header for Import-Library given below,and it got deployed properly.
Import-Library: org.springframework.spring;version="[3.0.5.RELEASE,3.0
.5.RELEASE]"
my libd file is present in the virgo/repository/ext.
When i deleted the work folder in virgo all together,restarted the server,and then tried to deploy the same bundle,I got the following error
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'hello-world' at version '1.0.0': A library with the name 'org.springframework.spring' and a version within the range '[3.0.5.RELEASE, 3.0.5.RELEASE]' could not be found
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.createExceptionForMissingLibrary(ImportExpansionHandler.java:184)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getLibraryPackageImports(ImportExpansionHandler.java:451).
My LIBD file is present in the same location as it was (virgo/repository/ext).
I am puzzled by seeing this error.If I use Import-Bundle directly instead of library it worked properly.
Why Virgo is not able to read the .libd file present in the location.
Any help on this is appreciated.
OK
Re: Unable to find Library ( .libd ) file Error [message #835412 is a reply to message #835023] Tue, 03 April 2012 03:08 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
Did you try starting Virgo with the -clean switch?
Re: Unable to find Library ( .libd ) file Error [message #836250 is a reply to message #835412] Wed, 04 April 2012 05:17 Go to previous messageGo to next message
Hi Glyn,
Thanks for your respose.I am still facing this issue even after using -clean to start the virgo.
Error log
[2012-04-03 16:35:29.152] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'datasource-1.0.0-20120330.114422-3.jar'.
[2012-04-03 16:35:29.175] fs-watcher <DE0000I> Installing bundle 'datasource' version '1.0.0.SNAPSHOT'.
[2012-04-03 16:35:29.186] fs-watcher <DE0002E> Installation of bundle 'datasource' version '1.0.0.SNAPSHOT' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Unsatisfied dependency detected when expanding imports for [bundle 'datasource' version '1.0.0.SNAPSHOT' in scope 'null']
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.expandImports(ImportExpandingTransformer.java:116)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer$ImportExpandingTreeVisitor.visit(ImportExpandingTransformer.java:80)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit(ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.transform(ImportExpandingTransformer.java:58)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessTree(TransformationStage.java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:285)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:164)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:136)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:203)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeploymentFileSystemListener.java:174)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeploymentFileSystemListener.java:186)
at org.eclipse.virgo.kernel.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeploymentFileSystemListener.java:87)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:245)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:166)
at org.eclipse.virgo.kernel.deployer.hot.WatchTask.run(WatchTask.java:58)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'datasource' at version '1.0.0.SNAPSHOT': A library with the name 'org.springframework.spring' and a version within the range '[3.0.5.RELEASE, 3.0.5.RELEASE]' could not be found
Re: Unable to find Library ( .libd ) file Error [message #836305 is a reply to message #836250] Wed, 04 April 2012 06:28 Go to previous message
This is strange and unexpected. I presume you can re-create this problem when starting Virgo from the command line with the -clean switch (rather than starting Virgo in Eclipse)? If so, I wonder if you could try to recreate the issue with a fresh install of Virgo and a trivial bundle which simply imports the Spring library. If the problem re-creates, you could then raise a bug which we could look at.
I was intrigued, so I tried to re-create the problem. I unzipped and started VTS 3.0.1.RELEASE, deployed a test bundle containing only the following manifest, stopped Virgo, deleted the work directory, and then re-started Virgo. The test bundle was successfully deployed, as expected. Perhaps you have modified the repository configuration?
Manifest-Version: 1.0
Bundle-SymbolicName: test.spring.library
Bundle-ManifestVersion: 2
Import-Library: org.springframework.spring;version="[3.0.5.RELEASE,3.0.5.RELEASE]"
Previous Topic:Why is there a uses conflict without disjoint ranges?
Next Topic:CME Group Experience of Virgo
Current Time: Sat May 25 02:06:19 EDT 2013
Powered by FUDForum. Page generated in 0.01970 seconds
