Home » Eclipse Projects » Koneki » feature request: highlight globals
feature request: highlight globals [message #835000] Mon, 02 April 2012 13:05 Go to next message
Jay Carlson is currently offline Jay Carlson
One of the most common errors in Lua is to misspell an identifier. If you have
local tests
print(test)
test will refer to a global. The AST contains this information. Many code styles, especially for modules, do not use globals much outside of local foo=foo imports. A visual highlight on test in
print(test)
would help people coding this way.
I don't know much about the DLTK, but Smalltalk has a cheap non-typed typo checker for method selectors. Translated to Lua, an occurrence of foo.testt is likely to be a typo unless somewhere else in the program any
bar.testt=...
exists. That seems harder though.
Re: feature request: highlight globals [message #837425 is a reply to message #835000] Thu, 05 April 2012 12:46 Go to previous messageGo to next message
Benjamin CABE is currently offline Benjamin CABE
Jay,
Semantic highlighting would be a great addition indeed, especially to spot typos more easily as you suggest.
Could you please file a feature request in the bug tracker of the project?
Thanks for the suggestion!
Re: feature request: highlight globals [message #839425 is a reply to message #837425] Sun, 08 April 2012 13:52 Go to previous messageGo to next message
Benjamin Cabe wrote on Thu, 05 April 2012 18:46
I have just opened bug 376301, and the fix is on its way Smile.
It will be committed in the github fork, since this is where the AST is in a good enough shape.
Re: feature request: highlight globals [message #840041 is a reply to message #839425] Mon, 09 April 2012 11:40 Go to previous message
Cool! I'm sorry I didn't get to the tracker--work got crazy.
There are probably a lot of interesting things that can be done once the AST is exposed to the highlight engine. I had no idea how to start. Thanks.
Previous Topic:debugging lua 5.2
Next Topic:"realtime" console update?
Current Time: Tue May 21 09:07:37 EDT 2013
Powered by FUDForum. Page generated in 0.02011 seconds
