Home » Eclipse Projects » XML Schema Definition (XSD) » Include several XSD files
Include several XSD files [message #824425] Mon, 19 March 2012 12:52 Go to next message
Ricardo Ben Amor is currently offline Ricardo Ben Amor
Member
I have a general question about my problem. I have un XSD files which include other XSD files. I have never work with several XSD files, just one for now.
Does the application work correctly if i have several XSD files in my project?
Thanks in advance,
Best Regards,
Re: Include several XSD files [message #824544 is a reply to message #824425] Mon, 19 March 2012 15:57 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Ricardo,
I'm not sure what specifically you're referring to as "the application"
but certainly the XSD model can work with includes.
On 19/03/2012 5:52 PM, Ricardo Ben Amor wrote:
> just one for now. Does the application work correctly if i have
> Thanks in advance,
> Best Regards,
Re: Include several XSD files [message #834978 is a reply to message #824425] Mon, 02 April 2012 12:33 Go to previous message
Member
Thanks for your answer. Indeed, you're right. I try to import some xsd files and it works properly.
Previous Topic:Problem with xsd and xml validation using JAXB
Next Topic:Inline embedded Schema
Current Time: Sat May 18 16:39:03 EDT 2013
Powered by FUDForum. Page generated in 0.01945 seconds
