Home » Modeling » M2T (model-to-text transformation) » [SOLVED (+ or -)] JET context.getVariable returning AnyTypeImpl(AnyTypeImpl cannot be cast to <my ecore class>)
icon7.gif  [SOLVED (+ or -)] JET context.getVariable returning AnyTypeImpl [message #831929] Thu, 29 March 2012 10:31 Go to next message
daniel conrado is currently offline daniel conrado
In my template, I have this:
<%@jet imports="mymodel.*"%>
<c:iterate select="/Robot/sensors" var="sensor">
Sensor s = (Sensor) context.getVariable("sensor");
But I'm getting this error:
java.lang.ClassCastException: org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl cannot be cast to mymodel.Sensor
I don't understand. What am I doing wrong?
Best Regards,
Daniel
[Updated on: Sat, 31 March 2012 10:03]
Report message to a moderator
Re: JET context.getVariable returning AnyTypeImpl [message #833450 is a reply to message #831929] Sat, 31 March 2012 10:03 Go to previous message
I still can't figure out how to access the Sensor object, but I've got a workaround for my problem. Here it is:
Instead of accessing the object, I write the values I want into variables, like this:
<c:setVariable var="sensorName" select="string($sensor/@name)"/>
And access this way:
final String sensorName = (String) context.getVariable("sensorName");
Hope it may be useful.
Thanks for reading.
Daniel
Previous Topic:[XPand] Eliminate Double Entries
Next Topic:[Acceleo/Xtext] Can I use files for concrete models created with xtext2 in acceleo?
Current Time: Thu May 23 10:32:52 EDT 2013
Powered by FUDForum. Page generated in 0.01648 seconds
