Home » Eclipse Projects » Nebula » Nebula xviewer column resize problem (Xviewer edit control does not resize with the table column cell size)
Nebula xviewer column resize problem [message #811462] Fri, 02 March 2012 06:20 Go to next message
shekhar singh is currently offline shekhar singh
Hi All ,
While editing the cell , control gets created with the same size as that of the table column cell . If i resize the table column cell ..the edit control that was created remains as is , it does not resize with the table column cell size .
Please find attached screen shot of this issue .
Thanks ,
shekhar
Re: Nebula xviewer column resize problem [message #832555 is a reply to message #811462] Fri, 30 March 2012 05:23 Go to previous message
Jürgen  Reichl is currently offline Jürgen Reichl
Hi shekhar,
please can you add this bug to bugzilla. (Nebula->XViewer)
Jürgen
[Updated on: Fri, 30 March 2012 05:24]
Report message to a moderator
Previous Topic:Change Section height of Gantt Diagram
Next Topic:gridtableviewer and drag and drop
Current Time: Thu May 23 16:30:29 EDT 2013
Powered by FUDForum. Page generated in 0.13330 seconds
