Home » Language IDEs » Java Development Tools (JDT) » Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger?
Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #831806] Thu, 29 March 2012 07:25 Go to next message
Alexey Romanov is currently offline Alexey Romanov
I can open org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader with "Open Type" (Ctrl+Shift+T) and see its source. However, when I see the same class in a debugger trace, I get "Source not found" message. How do I fix this?
Re: Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #831991 is a reply to message #831806] Thu, 29 March 2012 12:02 Go to previous messageGo to next message
Michael Rennie is currently offline Michael Rennie
Member
How are you debugging? If you are debugging a target workspace it all will "just work" if you are attaching the debugger in some other fashion you will have to update the source lookup path on your launch configuration accordingly.
Re: Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #832014 is a reply to message #831991] Thu, 29 March 2012 12:42 Go to previous messageGo to next message
I am launching application from Eclipse in the usual way.
How can I find where "Open Type" is getting the source from?
Re: Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #832711 is a reply to message #832014] Fri, 30 March 2012 09:43 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
On the Launch Config dialog, there is a Source tab that you can use to set the source location. Check there to see if something is messed up.
Re: Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #832717 is a reply to message #832711] Fri, 30 March 2012 09:52 Go to previous messageGo to next message
There is in Java Application launch configuration, but not in Eclipse Application.
Re: Why can I see source of (e.g.) DefaultClassLoader in "Open Type" but not in debugger? [message #832847 is a reply to message #832717] Fri, 30 March 2012 13:08 Go to previous message
I'm not understanding what your post is saying exactly. The Source tab is on the Java Application launch configuration dialog.
Previous Topic:Javascript ide does not show dom spelling errors
Next Topic:Indigo update site "Pending..." forever and "Failed to read repository"
Current Time: Sat May 18 09:10:45 EDT 2013
Powered by FUDForum. Page generated in 0.03166 seconds
