Home » Eclipse Projects » Virgo » Virgo web server(tomcat) 3.0.0(bundle failed to started)
Virgo web server(tomcat) 3.0.0 [message #760413] Fri, 02 December 2011 05:18 Go to next message
karthik elavan is currently offline karthik elavan
Member
Hello friends,
I have using virgo web server 2.1.0 and spring osgi technology in my project and working fine. but I have move to virgo web server 3.0.0 using my project came to error below that.
Failed to start web bundle 'sample-web' version '0.0.0': consult serviceability/logs/log.log for further details.
[2011-12-02 15:21:08.236] start-signalling-4 <DE0006E> Start failed for bundle 'sample-web' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:132)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:247)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:294)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:291)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:229)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:143)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:108)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
... 8 common frames omitted
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:91)
... 9 common frames omitted
[2011-12-02 15:21:08.248] start-signalling-4 <DE0010I> Stopping bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.250] start-signalling-4 <DE0011I> Stopped bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.252] TCP Connection(4)-127.0.0.1 <DE0013I> Uninstalling bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.265] TCP Connection(4)-127.0.0.1 <DE0014I> Uninstalled bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.471] TCP Connection(4)-127.0.0.1 <DE0000I> Installing bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.502] TCP Connection(4)-127.0.0.1 <DE0001I> Installed bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.516] TCP Connection(4)-127.0.0.1 <DE0004I> Starting bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.524] start-signalling-4 <DE0005I> Started bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:12.790] start-signalling-2 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.splash' version '3.0.0.RELEASE' with context path '/'.
[2011-12-02 15:21:12.791] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.splash' version '3.0.0.RELEASE'.
My project environment :
Linux OS, Spring MVC, OSGI Frame Work Currently using virgo web server 2.1.0 it's working fine and deployed war file also fine.
NOTE: But still now i am facing the problem, at the same project i have change the runtime server configure change the virgo web server 3.0.0, Its not run the project otherwise came to bundle startup error.
Please help me any body. ASAP.....
[Updated on: Fri, 02 December 2011 05:19]
Report message to a moderator
Re: Virgo web server(tomcat) 3.0.0 [message #760422 is a reply to message #760413] Fri, 02 December 2011 05:37 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn Normington
Try this FAQ for starters: http://wiki.eclipse.org/Virgo/FAQ#My_Web_Application_Bundle_stopped_working_when_I_moved_to_Virgo_3.x._What_happened.3F
If that doesn't work, then next step is to look at the logs.
Re: Virgo web server(tomcat) 3.0.0 [message #760582 is a reply to message #760422] Sat, 03 December 2011 02:17 Go to previous messageGo to next message
Member
Did given the link i follow and changes for my server but i did not solve the issue please any think another way let you know please help me
Re: Virgo web server(tomcat) 3.0.0 [message #760593 is a reply to message #760582] Sat, 03 December 2011 04:43 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
Can you check the logs in serviceability directory for exceptions related to your application?
Re: Virgo web server(tomcat) 3.0.0 [message #760595 is a reply to message #760593] Sat, 03 December 2011 05:20 Go to previous messageGo to next message
Member
Did you given the information i have to follow but does not have any bug identified please help me, currently my war file 2.1.0 and 2.1.1 is working with fine. then i move to higher version it's not started for bundle especially web application bundle is not started.. please ASAP
Thanks for replay
karthik
Re: Virgo web server(tomcat) 3.0.0 [message #761013 is a reply to message #760595] Mon, 05 December 2011 14:20 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta Georgieva
Can you tell me what is the value for WABHeaders property.
Can you log also to telnet then invoke "b <bundle-id-for-your-web-app>" and post here the Bundle-Classpath header value?
Do you have something in <VIRGO-HOME>/serviceability/logs/log.log?
Re: Virgo web server(tomcat) 3.0.0 [message #761289 is a reply to message #761013] Tue, 06 December 2011 03:47 Go to previous messageGo to next message
Member
Hi Violeta Georgieva,
I have follow your information please below the your instruction:
* Can you tell me what is the value for WABHeaders property. (this is your instruction)
I try to change the value for Virgo home-->repository-->ext-->org.eclipse.viro.wep.prop-->WABHeaders=strict replaced to defaulted it's correct
* Can you log also to telnet then invoke "b <bundle-id-for-your-web-app>" and post here the Bundle-Classpath header value?
How to invoke the bundle id in my web application
* Do you have something in <VIRGO-HOME>/serviceability/logs/log.log?
I have check this log detail but i dont ant idea?
[2011-12-06 14:07:39.902] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]'
[2011-12-06 14:07:39.903] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default WE0000I Starting web bundle 'sample-web' version '0.0.0' with context path '/sample-web'.
[2011-12-06 14:07:39.915] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-web_0.0.0, BundleEvent STARTED
[2011-12-06 14:07:39.915] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:39.915] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.544] INFO Thread-49 o.a.c.c.C.[Catalina].[localhost].[/sample-web] Initializing Spring root WebApplicationContext
[2011-12-06 14:07:40.545] INFO Thread-49 System.out INFO : org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
[2011-12-06 14:07:40.568] INFO Thread-49 System.out ERROR: org.springframework.web.context.ContextLoader - Context initialization failed
[2011-12-06 14:07:40.568] INFO Thread-49 System.out java.lang.NoSuchMethodError: org.springframework.web.context.ConfigurableWebApplicationContext.setId(Ljava/lang/String;)V
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:264)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4723)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5226)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5221)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at java.util.concurrent.FutureTask.run(FutureTask.java:138)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.lang.Thread.run(Thread.java:619)
[2011-12-06 14:07:40.572] ERROR Thread-49 o.a.c.c.C.[Catalina].[localhost].[/sample-web] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener java.lang.NoSuchMethodError: org.springframework.web.context.ConfigurableWebApplicationContext.setId(Ljava/lang/String;)V
[2011-12-06 14:07:40.573] ERROR start-signalling-1 org.apache.catalina.core.StandardContext Error listenerStart
[2011-12-06 14:07:40.573] ERROR start-signalling-1 org.apache.catalina.core.StandardContext Context [/sample-web] startup failed due to previous errors
[2011-12-06 14:07:40.593] INFO ication=none,J2EEServer=none o.a.c.c.C.[Catalina].[localhost].[/sample-web] Closing Spring root WebApplicationContext
[2011-12-06 14:07:40.650] ERROR start-signalling-1 org.eclipse.gemini.web.internal.StandardWebApplication Failed to start web application at bundleContext path '/sample-web' org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.653] ERROR start-signalling-1 org.eclipse.virgo.medic.eventlog.default WE0005E Failed to start web bundle 'sample-web' version '0.0.0': consult serviceability/logs/log.log for further details.
[2011-12-06 14:07:40.653] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.653] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.654] INFO start-signalling-1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate start failed (stop) event to
[2011-12-06 14:07:40.659] ERROR start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0006E Start failed for bundle 'sample-web' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cashmiddletier-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.665] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0010I Stopping bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.666] INFO start-signalling-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Bundle 'cashmiddletier-web_0.0.0 [135]' has stopped. Removing its related tracking state.
[2011-12-06 14:07:40.667] INFO start-signalling-1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate stopped event to
[2011-12-06 14:07:40.667] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0011I Stopped bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.668] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent STOPPED
[2011-12-06 14:07:40.668] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.668] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.668] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.669] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0013I Uninstalling bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.669] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.673] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent UNRESOLVED
[2011-12-06 14:07:40.674] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing uninstalled event for bundle 'sample-web' version '0.0.0'
[2011-12-06 14:07:40.675] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate uninstalled event to
[2011-12-06 14:07:40.676] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0014I Uninstalled bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.677] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent UNINSTALLED
[2011-12-06 14:07:40.677] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.683] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle org.eclipse.osgi_3.7.0.v20110613, FrameworkEvent PACKAGES REFRESHED
[2011-12-06 14:07:40.701] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.707] ERROR TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.deployer.management.StandardDeployer Exception filtered from JMX invocation org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cashmiddletier-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.769] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing installing event for bundle 'sample-dm' version '0.0.0'
[2011-12-06 14:07:40.771] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'cashmiddletierservice-dm' version '0.0.0'.
[2011-12-06 14:07:40.773] INFO TCP Connection(3)-127.0.0.1 o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator Calculating missing dependencies of bundle(s) 'sample-dm_0.0.0'
[2011-12-06 14:07:40.777] INFO TCP Connection(3)-127.0.0.1 o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator The dependencies of '[sample-dm_0.0.0]' are '[]'
[2011-12-06 14:07:40.778] INFO TCP Connection(3)-127.0.0.1 o.eclipse.virgo.kernel.model.internal.bundle.ModelBundleListener Processing installed event for bundle 'sample-dm:0.0.0' in region 'org.eclipse.virgo.region.user'
[2011-12-06 14:07:40.779] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent INSTALLED
[2011-12-06 14:07:40.780] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.781] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.782] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent RESOLVED
[2011-12-06 14:07:40.782] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.782] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Adding signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1' for bundle 'sample-dm_0.0.0 [136]'
[2011-12-06 14:07:40.784] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-dm' version '0.0.0' in scope 'null' to propagate starting event to
[2011-12-06 14:07:40.784] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.785] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Non-Spring DM powered bundle 'sample-dm_0.0.0 [136]' has started. Driving signals '[org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1]'.
[2011-12-06 14:07:40.785] INFO start-signalling-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Driving signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1'
[2011-12-06 14:07:40.785] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=cashmiddletierservice-dm_0.0.0]'
[2011-12-06 14:07:40.786] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.786] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletierservice-dm_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.787] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent STARTED
[2011-12-06 14:07:40.787] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.787] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
Please help me...
Re: Virgo web server(tomcat) 3.0.0 [message #761558 is a reply to message #761289] Tue, 06 December 2011 11:49 Go to previous messageGo to next message
Having in mind the other thread that you've posted where you wrote that you succeeded to solve the issues, is this error still valid?
Re: Virgo web server(tomcat) 3.0.0 [message #825060 is a reply to message #761558] Tue, 20 March 2012 08:11 Go to previous messageGo to next message
Member
Kindly I want another one help, at the very first i am developing my application 2.0.1 and 2.1.1 it's working fine my application and war file, after i move to another level means next version 3.0.0, 3.0.1 and 3.0.2 virgo server deployed my application was bundle failed exception came to me, so i had follow the your instruction for changing that property for org.eclipse.virgo.web.properties --> replaced WABHeaders=strict to WABHeaders=defaulted it's application war file working fine and fixed issue, but i want another requirement for my project manager ask to me to fixing this issue without changed the property file parameter, So please if there any idea or way let me know...
I expecting your valuable instruction....
karthik
Re: Virgo web server(tomcat) 3.0.0 [message #825437 is a reply to message #825060] Tue, 20 March 2012 16:59 Go to previous messageGo to next message
One option is to deploy WAB instead of a traditional web application.
Another option: we may downport to 3.0.x the fix for https://bugs.eclipse.org/bugs/show_bug.cgi?id=354730 that I'm preparing.
Re: Virgo web server(tomcat) 3.0.0 [message #827389 is a reply to message #825437] Fri, 23 March 2012 05:05 Go to previous messageGo to next message
Member
i do not understand in this url : https://bugs.eclipse.org/bugs/show_bug.cgi?id=354730 , how can i put in my application this Java class or anything...
did you given the information steps
1.what is deploy WEB instead of traditional web application ?
2.what is Patch in WebBundleTransformer
i have more doubt in this information simply where it will be i implemented the step two i mean WebBundleTransformer.java file please help me....
karthik
Re: Virgo web server(tomcat) 3.0.0 [message #831202 is a reply to message #827389] Wed, 28 March 2012 11:49 Go to previous message
No the idea was that I'm going to downport that fix to 3.0.x Wink
Previous Topic:Virgo server memory problem
Next Topic:JDK 7 bundles?
Current Time: Thu May 23 20:50:32 EDT 2013
Powered by FUDForum. Page generated in 0.01880 seconds
