Home » Language IDEs » Java Development Tools (JDT) » How to get the compilation unit produced by the compiler
How to get the compilation unit produced by the compiler [message #830403] Tue, 27 March 2012 11:24 Go to next message
Fabrice Marcelin is currently offline Fabrice Marcelin
Hello there,
Instead of creating a compilation unit from AST, I was wondering if it is possible to get a hold on the compilation unit that the compiler produced.
Thanks in advance.
Re: How to get the compilation unit produced by the compiler [message #830928 is a reply to message #830403] Wed, 28 March 2012 04:30 Go to previous message
Satyam Kandula is currently offline Satyam Kandula
The compilation unit that compiler produced is internal and it is exposed outside through the DOM/AST. Here are some internal ways to get hold of the internal CompilationUnit.
- If you use setResolveBindings(true) while creating the AST, the references to the internal CompilationUnit is still kept at DefaultBindingResolver#newAstToOldAst.
- Look at org.eclipse.jdt.internal.compiler.Compiler.compile(ICompilationUnit[]) and it's references and see if you want to call directly.
Note that internal types/methods are liable to change which could break your code.
Previous Topic:Move refactoring programmatically
Next Topic:Eclipse's rename refactoring in code
Current Time: Fri May 24 03:41:22 EDT 2013
Powered by FUDForum. Page generated in 0.02883 seconds
