karthik elavan Messages: 70 Registered: August 2011 Location: Chennai
Member
Very Urgent :- My application going to deployed production server
I have a problem in virgo tomcat sever 3.0.2. After deployed my application war file in virgo-tomcat-server-3.0.2, Every 3 mins virgo server memory usage goes peak. Even though if I did not use my application the virgo server memory usage is going to peak.
Is anything problem with the deployment or any virgo server settings changes need?
You need to do more background work so that the people on this forum are more likely to help you. For example, can you reproduce the problem with a fresh unzip of VTS 3.0.2? If so, what OS and JVM are you using. What JVM parameters are you specifying? If you are taking the defaults, what are they for the JVM you are using? Is there anything which might be slightly unusual about your installation? If you can do this background work, you may find the problem yourself while doing those checks. But if you can reproduce the problem with a fresh unzip, you'll be in a better position to raise a reproducible bug.
Hope that helps you make great forum posts in the future!
Member
oh, Sorry unfortunately i post wrong information given actually that pbm is not came to my local machine, that problem was came to production server, So i will check jvm parameter.
Our system operating system : linux kubundu 10.1
I get back to detail information given to you later
