Home » Eclipse Projects » BIRT » Using jQuery UI in a report
Using jQuery UI in a report [message #827578] Fri, 23 March 2012 10:29 Go to next message
Alexey Romanov is currently offline Alexey Romanov
How can I use jQuery UI in a BIRT report item presentation? Where do I need to put the images, JS and CSS files so the viewer and "show as HTML" will be able to access them? Of course, JS and CSS can be just emitted into generated HTML, but that doesn't work for images.
Re: Using jQuery UI in a report [message #827766 is a reply to message #827578] Fri, 23 March 2012 15:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
In the viewer (Plugin and deployed runtime) you could include these in the
\webcontent\birt\styles
\webcontent\birt\js
\webcontent\birt\images
directories. I would be very interested to see how you are planning on
using these.
Jason
Jason Weathersby
BIRT Exchange
Re: Using jQuery UI in a report [message #827815 is a reply to message #827766] Fri, 23 March 2012 16:43 Go to previous messageGo to next message
using these.
Still working on my plan to add parameter entry into HTML reports. And I want to use http://trentrichardson.com/examples/timepicker/ for date/time/datetime parameters instead of requiring the users to get the format right in textboxes Smile This is planned to be opensourced when it gets to an usable state.
[Updated on: Fri, 23 March 2012 16:45]
Report message to a moderator
Re: Using jQuery UI in a report [message #830731 is a reply to message #827815] Tue, 27 March 2012 22:07 Go to previous message
Let me know if you need some help.
Jason
> using these.
> date/time/datetime parameters instead of having to get the format right
> in textboxes :) This is planned to be opensourced when it gets to an
> usable state.
Jason Weathersby
BIRT Exchange
Previous Topic:Image tutorial please!!
Next Topic:var OR dynamic data set OR??
Current Time: Thu May 23 08:43:51 EDT 2013
Powered by FUDForum. Page generated in 0.02240 seconds
