Home » Eclipse Projects » ACTF » miChecker Export
miChecker Export [message #829633] Mon, 26 March 2012 11:23 Go to next message
JoAT MoN is currently offline JoAT MoN
Hello ACTF developers,
I'm hoping that you can help with this issue...
So I've downloaded and installed everything according to the miChecker PDF, and I can get the "Launch an Eclipse Application" working, but when I try to export miChecker, I get the following issue:
Processing inclusion from feature org.eclipse.actf.examples.michecker.nl1: Unable to find plug-in: org.eclipse.core.commands.nl_ja_0.0.0. Please check the error log for more details.
The first line from the log states:
Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. org.eclipse.actf.examples.michecker Build path JRE System Library Problem
Any tips?
Re: miChecker Export [message #830368 is a reply to message #829633] Tue, 27 March 2012 10:42 Go to previous message
Kentarou Fukuda is currently offline Kentarou Fukuda
Member
Thank you for trying ACTF and miChcker!
It seems to be caused by a lack of Japanese language packages.
Would you please try either way of 1) or 2) below?
1) Remove dependency
- Open feature.xml in org.eclipse.actf.examples.michecker-feature package.
- Select "Included Features" tab, and then delete "org.eclipse.actf.examples.michecker.nl1" from "Included Features" list.
- try "export" again.
2) Add Japanese language package into your environment
- Download BabelLanguagePack-eclipse-ja_3.6.0.v20101211043401.zip from
http://archive.eclipse.org/technology/babel/babel_language_packs/R0.8.1/helios.php#ja
- Unzip and install the language pack. (See Babel project's homepage for more details.)
Please let me know if you have any other questions.
Kentarou
Previous Topic:How to import .apk files into Eclipse
Next Topic:How to I put multiple buttons on one page on Eclipse for android app?
Current Time: Sat May 18 18:43:08 EDT 2013
Powered by FUDForum. Page generated in 0.01556 seconds
