| Popup menu disapears after reopen a part [message #827586] |
Fri, 23 March 2012 10:34  |
Tom K. Messages: 22 Registered: July 2009 |
Junior Member |
We have a Problem with our context menu.
In our Part (in the @PostConstruct method) we register the menu
menuService.registerContextMenu(control, Constants.CONTEXT_MENU_ID);
the first time it works well and shows all Popup Menus defined in the fragment.e4xmi
when the view is closed (flag set To be Rendered false and again set to true. Then the menu disapears. In the livemodel the menu is still there and declared. As well the code in the @PostConstruct is called again.
Does anybody know why this problem could happen? It is probably a bug?
We are using M4...
[Updated on: Fri, 23 March 2012 10:35] Report message to a moderator
FUDForum. Page generated in 0.01620 seconds
