| Re: missing builders and cant deploy to tomcat (Eclipse Indigo) [message #825931 is a reply to message #825879] |
Wed, 21 March 2012 08:36   |
Russell Bateman Messages: 2707 Registered: July 2009 Location: Provo, Utah, USA |
On 2012.03.21 5:25, F L wrote:
> Hi, I just installed Eclipse Indigo and Apache Tomcat 7.0.
> If I right-click on my project -> Builders it shows missing builders:
> com.genuitec.eclipse.j2eedt.core.J2EEProjectValidator
> com.genuitec.eclipse.j2eedt.core.WebClasspathBuilder
> com.genuitec.eclipse.j2eedt.core.DeploymentDescriptorValidator
> com.genuitec.eclipse.ast.deploy.core.DeploymentBuilder
> In addition, if I right-click on Tomcat (in the Servers view) -> Add and
> remove... -> put my project under Configured box, and nothing happens,
> Eclipse does not Publish (deploy) my project to tomcat's webapps directory.
> So, how can I get these missing builders, and there is any relation
> between missing builders and that I can deploy my project?
> And if there is no relation, how can I deploy?
> Thank you!
This is a question for the Eclipse web tools forum.
Eclipse doesn't deploy your application to Tomcat in the way you think.
Instead, it deploys it to a mock Tomcat filesystem in the workspace, on
the path <workspace>/.metadata/.plugins/org.eclipse.wst.server.core/tmpN
where N is a digit corresponding to respective Tomcat runtimes (minus 1)
you have associated with Eclipse (usually one, therefore tmp0).
As for the missing builders, as I say, ask in the other forum.
Best of luck.
| Re: missing builders and cant deploy to tomcat (Eclipse Indigo) [message #826718 is a reply to message #826522] |
Thu, 22 March 2012 08:19  |
On 2012.03.22 1:03, F L wrote:
> Dear Russell Bateman and Nitin Dahyabhai!
> Thank you for your answers good to know that.
> However, this did not resolve the problem that I can not use the system.
> I get this error during starting tomcat:
> java.lang.IllegalArgumentException: Document base
> C:\Work\eclipse-jee-indigo-SR2-win32\eclipse\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps\Work\eclipse-jee-indigo-SR2-win32\apache-tomcat-7.0.25\webapps\myproject\WEB-INF
> does not exist or is not a readable directory
> and when I try to reach the app from a browser I get 404. (Tomcat is
> running)
> I played with these settings:
> 1)
> In the server.xml file:
> <Host
> appBase="C:\Work\eclipse-jee-indigo-SR2-win32\apache-tomcat-7.0.25\webapps"
> autoDeploy="true" name="localhost" unpackWARs="true">
> <Context
> docBase="C:\Work\eclipse-jee-indigo-SR2-win32\apache-tomcat-7.0.25\webapps\myproject\WEB-INF"
> path="/" reloadable="true"
> source="org.eclipse.jst.jee.server:myproject"/></Host>
> 2)
> Resource:
> Path: /myproject
> Type: Project
> Location:
> C:\Work\eclipse-jee-indigo-SR2-win32\eclipse\workspace\myproject\webapp\myproject
> 3)
> Java build path -> Source:
> Allow output folders for source folders : checked
> Default output folder : myproject/war/WEB-INF/classes
> 4)
> Server: Tomcat v7.0 at localhost
> 5)
> Project Facets:
> Dynamic Web Module 3.0, Java, Javascript
> Runtimes: Tomcat v7.0
> Runtime composition: Apache Tomcat v7.0, Java Runtime Environment v1.7
> 6)
> I see that the project is compiled to:
> C:\Work\eclipse-jee-indigo-SR2-win32\eclipse\workspace\myproject\webapp\myproject\war\WEB-INF\classes
> Can you tell me what are the correct settings or what is missing?
> THANK YOU!
Again, --what Nitin said. I had forgotten that Genuitec was MyEclipse.
You'll do much better asking questions in their forum, not here. I only
used it a long time ago for a short time, but I remember their forum as
being quite responsive and helpful.
FUDForum. Page generated in 0.01638 seconds
