Home » Eclipse Projects » Standard Widget Toolkit (SWT) » segmentation fault indigo SR2 with glassfish 3.1.2 plugin(repeatable segmentation fault)
segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #825344] Tue, 20 March 2012 14:49 Go to next message
agks mehx is currently offline agks mehx
(cross-posted from eclipse platform forum)
I am persistently getting a repeatable segmentation fault crash when I run a simple project using the internal Glassfish server plugin and then attempt to navigate to any Java source file. If I open a Java file prior to running the project on the server, then I am able to switch to the window, but the segmentation fault happens when I make any simple code change.
It is so unstable it is unworkable. The segmentation fault happens with pretty much anything I try to do.
Operating System: Ubuntu 11.10 32-bit
Java Version: 1.7.0_03
Glassfish Plugin:
Eclipse Version: Indigo SR2 (this was happening with SR1 also)
Glassfish Application Server: Version 3.1.2.0 from the server download.java.net and directory /glassfish/eclipse/indigo (I am not allowed to post links yet)
(I downloaded the latest versions of all of the above today itself)
Re: segmentation fault indigo SR2 with glassfish 3.1.2 plugin [message #826574 is a reply to message #825344] Thu, 22 March 2012 04:34 Go to previous message
Lakshmi Shanmugam
Hi, Can you post the stack from the crash log?
Lakshmi P Shanmugam
Previous Topic:Launch standalone app outside of eclipse
Next Topic:Dispose question
Current Time: Sat May 18 06:54:51 EDT 2013
Powered by FUDForum. Page generated in 0.02072 seconds
