Home » Eclipse Projects » Virgo » Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work
Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work [message #819978] Tue, 13 March 2012 11:19 Go to next message
Jason Levine is currently offline Jason Levine
I currently have a bunch of EclipseRT Bundle projects in Eclipse, and when I deploy them to my version of Virgo Tomcat I'm running as a server in Eclipse, they appear to try to deploy as plain WAR files, not as the WABs that they are. I'm adding them to the server as described in the Virgo Programmer Guide section 7.7 (using the "Add and Remove" dialog); I see them deploy, but they don't deploy to the Web-ContextPath that's defined in their MANIFEST.MF files, and when I look in the /stage/ and /work/org.eclipse.virgo.kernel.deployer_3.0.2.RELEASE/staging/global/bundle/ subdirectories of my Virgo Tomcat installation directory, I see that there's a .war entry for my project; it's a tiny tiny WAR file that simply contains an empty WEB-INF/classes directory and a META-INF/MANIFEST.MF file with "Manifest-Version: 1.0" and nothing else.
Is there a setting on my project somewhere that makes it behave with the embedded Virgo server like the WAB it really is? Note that if I build my project external to Eclipse -- using Maven, issuing "mvn package" -- then it perfectly builds my .jar file that I can either upload to the Virgo server using the admin interface or throw into the /pickup/ subdirectory to have it grab it automatically. But I'd love to work out using the built-in Virgo server in Eclipse, so I can debug without having to go through the manual build/redeploy stage.
I'm using the latest snapshot of the Eclipse Virgo Tools (1.0.0.201203100237-SNAPSHOT), and Virgo Tomcat 3.0.2.RELEASE.
Thanks in advance....
Jason
Re: Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work [message #825431 is a reply to message #819978] Tue, 20 March 2012 16:50 Go to previous messageGo to next message
Miles Parker is currently offline Miles Parker
Hi Jason,
Sorry we missed this one! Is it possible you're hitting:
333343: Incorrect packaging of JAR dependencies when deploying WAR to Embedded Virgo via STS/Eclipse
https://bugs.eclipse.org/bugs/show_bug.cgi?id=333343
cheers,
Miles
Re: Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work [message #825979 is a reply to message #825431] Wed, 21 March 2012 09:52 Go to previous messageGo to next message
I don't think I'm hitting that -- if you note, I'm getting functionally NO contents in my WAR file, and that bug seems to imply that it's only the packaged libraries that are affected. Likewise, there's the context path issue -- they're simply deployed to the incorrect context path.
Re: Deploying EclipseRT bundles to Eclipse-embedded Virgo Tomcat doesn't work [message #826556 is a reply to message #825979] Thu, 22 March 2012 04:09 Go to previous message
Glyn Normington is currently offline Glyn Normington
I guess this could be related to the variety of symptoms that were reported under https://bugs.eclipse.org/bugs/show_bug.cgi?id=342552
Jason: it sounds like this is happening repeatably. If so, would it be possible to package up a minimal project that exhibits the problem?
Previous Topic:Servlet ClassNotFound exception
Next Topic:Virgo White Paper
Current Time: Sun May 19 10:44:53 EDT 2013
Powered by FUDForum. Page generated in 0.01748 seconds
