| IntegrityChecker with PostgreSQL [message #826543] |
Thu, 22 March 2012 03:38  |
Christoph L Messages: 7 Registered: January 2012 |
Junior Member |
Environment: EclipseLink 2.3.2, PostgreSQL 9.1 on Windows
I'm trying to use the IntegrityChecker. I registered my session customizer and activated the default IntegrityChecker. It complains about missing tables that in reality exist (I also let EcliseLink generate the schema to verify I didn't do something wrong). I debugged it a bit and found that in IntegrityChecker#initializeTables it uses row.get("TABLE_NAME") to read a table name. But this returns null because in the row the key is "table_name".
Then i used my custom IntegrityChecker which "fixes" this, but there's the same issue with column names. They are checked in ClassDescriptor which isn't so easy to change afaik.
I suspect that IntegrityChecker works but my configuration is somehow broken. The PostgreSQLPlatform is set correctly. Any ideas what I could try?
FUDForum. Page generated in 0.47413 seconds
