Home » Language IDEs » Java Development Tools (JDT) » Eclipse Resource on compilation error
Eclipse Resource on compilation error [message #825646] Wed, 21 March 2012 00:23 Go to next message
Fabrice Marcelin is currently offline Fabrice Marcelin
I would like to reproduce some of the errors found in IProblem constant fields and I was wondering if there are Eclipse resources on how to purposefully trigger those errors. For instance, if I want to trigger the problem IProblem.ParsingErrorInsertToComplete I just have omit a semicolon.
Re: Eclipse Resource on compilation error [message #825676 is a reply to message #825646] Wed, 21 March 2012 01:28 Go to previous message
Deepak Azad is currently offline Deepak Azad
Look in
/org.eclipse.jdt.core/compiler/org/eclipse/jdt/internal/compiler/problem/messages.properties.
This contains the corresponding messages for the problem ids, that
should give you a hint.
Deepak Azad
http://wiki.eclipse.org/JDT/FAQ
Previous Topic:segmentation fault indigo SR2 with glassfish 3.1.2 plugin
Next Topic:Debugging exploded EAR Application in eclipse
Current Time: Thu May 23 00:55:11 EDT 2013
Powered by FUDForum. Page generated in 0.01487 seconds
