| Cannot use window builder on e4 [message #825099] |
Tue, 20 March 2012 09:16  |
Phill Perryman Messages: 201 Registered: July 2009 |
I have installed 4.2M6 and updated it with e4 M6 stable build. I then installed
Windowbuilder - http://download.eclipse.org/windowbuilder/WB/integration/4.2/
If I do anything, for example new SWT composite it creates a small window builder window in the top left of the editor area, a red x icon, the message "Failed to". There is also an unhandled event loop exception generated. Does window builder work with e4.
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalArgumentException: Argument not valid)
at org.eclipse.swt.SWT.error(SWT.java:4361)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
plus lots more the same
FUDForum. Page generated in 0.02746 seconds
