| [EMFStore] and UML2 [message #825005] |
Tue, 20 March 2012 06:40  |
Peter Messages: 82 Registered: July 2009 |
Member |
I am interested to store my UML2 Models in an EMFStore Repository. As
far as I understand the mechanism a model must be generated with the
Containment Proxies option set to true. The UML2 Model is generated with
the option set to true but it does not appear when I want to create a
new model element. Does anybody know the problem? Because of the own
GenModel?
Thanks in advance
Cheers Peter
| Re: [EMFStore] and UML2 [message #825854 is a reply to message #825816] |
Wed, 21 March 2012 06:36   |
Member |
Hi Jonas and Maximilian,
works well but it seems like that stereotypes are not supported and the
ECP approach is quite different...
I will look at it.
Thanks for you help!
Cheers
Peter
Am 21.03.2012 10:37, schrieb Jonas Helming:
> I would like to add the EMF Client Platform is probably not the best way
> to modify UML models, as it is very much focused on form-based editing.
> There are probably some parts which cannot be edited such as diagrams.
> Best Regards
> Jonas
> Am 20.03.2012 21:45, schrieb Maximilian Koegel:
>> Hi Peter,
>> EMFStore uses EMF Client Platform (ECP) to provide editors for the
>> model. ECP has an extension point to allow to point to the model
>> packages that should be displayed in the new dialog. If no packages are
>> registered it tries to "guess" the right package by excluding all model
>> packages that ship with the Eclipse Modeling Tools including the UML2
>> package. Adding this extension will solve the problem:
>> <extension
>> point="org.eclipse.emf.ecp.model.ecppackage">
>> <modelPackage
>> modelPackage="http://www.eclipse.org/uml2/3.0.0/UML">
>> </modelPackage>
>> </extension>
>> Cheers,
>> Maximilian
>> Am 20.03.2012 11:40, schrieb Peter:
>>> Hi,
>>> GenModel?
>>> Thanks in advance
>>> Cheers Peter
| Re: [EMFStore] and UML2 [message #826646 is a reply to message #825854] |
Thu, 22 March 2012 06:27  |
Maximilian Koegel Messages: 118 Registered: July 2009 |
Hi Peter,
you can use EMFStore without ECP with your own editors. A good starting
point to the API is WorkspaceManager.getInstance.getCurrentWorkspace().
Let me know if I can get you any more help!
Maximilian
Am 21.03.2012 11:36, schrieb Peter:
> I will look at it.
> Cheers
> Peter
>> Best Regards
>> Jonas
>>> Hi Peter,
>>> <extension
>>> <modelPackage
>>> </modelPackage>
>>> </extension>
>>> Cheers,
>>> Maximilian
>>>> Hi,
>>>> with
>>>> GenModel?
>>>> Thanks in advance
>>>> Cheers Peter
FUDForum. Page generated in 0.01977 seconds
