Home » Eclipse Projects » Hudson » using parameters for scm plugins
using parameters for scm plugins [message #819898] Tue, 13 March 2012 09:12 Go to next message
amgad hanafy is currently offline amgad hanafy
I have multiple jobs that checkout from scm
I need all these job to be switched to checkout from branch or main using a parameter
is it possible and how
Re: using parameters for scm plugins [message #821357 is a reply to message #819898] Thu, 15 March 2012 04:46 Go to previous messageGo to next message
Duncan Mills is currently offline Duncan Mills
Yes this is simple.
If you have a parameter defined for the Job then you can reference that in the Repository URL:
e.g.
https ://myrepos.example.com/svn/BigProject/$useBranch
Where useBranch is defined as a job parameter (or is an environment variable)
Duncan Mills
Eclipse Hudson team
Re: using parameters for scm plugins [message #824297 is a reply to message #821357] Mon, 19 March 2012 10:01 Go to previous message
i tried it but got the following error
Couldn't find view $view in project E1020-VF UK Shop
where $view is the parameter used
have you tried it yourself ?
Previous Topic:Best practices for backup
Next Topic:Hudson and SWTBot screenshots
Current Time: Thu May 23 10:33:10 EDT 2013
Powered by FUDForum. Page generated in 0.01782 seconds
