Home » Modeling » M2T (model-to-text transformation) » [Acceleo] OO-semantics of templates
[Acceleo] OO-semantics of templates [message #823543] Sun, 18 March 2012 09:31 Go to next message
Gregor Bonifer is currently offline Gregor Bonifer
I stumbled upon the following behavior:
My idea was to seperate the traversal of a model from the creation of textual artifacts. The intention behind this is that a general strategy for walking a model may be used to create different kinds of textual representation that have a common structure.
First, I created a module walkInheritanceHierarchie with public templates walkPackage(pack : EPackage), walkRootClass(eClass : EClass, pack : EPackage) and walkSubClass(eClass : EClass, pack : EPackage):
- walkPackage calls walkRootClass for every EClass that doesn't have a superClass inside the package.
- walkRootClass calls walkSubClass for every direct subClass of the given class.
- walkSubClass calls itself for every direct subClass of the given class.
Now I wanted to create a simple xml-document reflecting the inheritance structure. So, I created a module renderHierarchieXML that extends walkInheritanceHierarchie.
I defined overriding templates for all three templates. Each template generates some text and calls [super/].
Now it seems that [super/]-call just delegates to the superTemplate which is then executed as if it was executed standalone. I would have expected that the template walkPackage calls the overriding version of walkRootClass, but instead it calls the overridden version from its own module. This means that the namespace used for the execution of super-calls does not respect the calling context. walkPackage seems to be unaware that it should not call walkRootClass from its own module, but the overriding template from the extending module.
Therefore the behavior does not resemble OO inheritance semantics.
What am I doing wrong? Did I misunderstand the concept behind the extending- and overriding-mechanism?
Gregor Bonifer
Re: [Acceleo] OO-semantics of templates [message #824071 is a reply to message #823543] Mon, 19 March 2012 04:11 Go to previous messageGo to next message
Hi Gregor
Acceleo is an implementation of most of the OMG MOFM2T 1.0
specification, which is a bit vague as to which module/template/query
concepts have namespace and which have class semantics. You are in good
company in observing a lack of reasonable polymorphism.
It is not entirely surprising that a 1.0 specification can be improved.
I hope that Obeo will start moving towards a 1.1 or 2.0 specifcation.
Ed Willink
On 18/03/2012 13:31, Gregor Bonifer wrote:
> I stumbled upon the following behavior: My idea was to seperate the
> superClass inside the package. - walkRootClass calls walkSubClass for
> Gregor Bonifer
Re: [Acceleo] OO-semantics of templates [message #827357 is a reply to message #824071] Fri, 23 March 2012 04:04 Go to previous message
Laurent Goubet is currently offline Laurent Goubet
Gregor,
The fact that a call to "super" goes up to the overriding template ... and never goes back down (if "super" calls an overriden template) is a known limitation of Acceleo, though I could not locate the bug which I thought was open for this issue. Could you track your problem (your previous description would be enough) on the bugzilla? https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T&component=Acceleo&hardware=All&os=All .
As Ed mentionned, the specification (you can find it there by the way : http://www.omg.org/spec/MOFM2T/1.0/ ) is quite vague as to the semantics of overriding, "super" calls, polymorphic dispatch... but as it stands, it is vague enough for us to think that the best implementation would be to be more "java-like" in the dispatching of template and query calls.
Laurent Goubet
Obeo
Previous Topic:MWE: Caching XML Schema to ECORE transformation
Next Topic:[ATL] The generate atl plugin works differently from atl configuration
Current Time: Thu May 23 00:10:08 EDT 2013
Powered by FUDForum. Page generated in 0.01813 seconds
