To add a bit. I also try using a dymanic XPath espression but with no
luck:-
<c:stringTokens string="{$action/@expression}" name="currentString"
delimitedBy=" ">
"Stu" <evaandoli@dodo.com.au> wrote in message
news:eufhr0$5d7$1@build.eclipse.org...
> I struggling to use the function c:stringTokens as I can't seem to plugin
> a string rather than a fixed string.
> The rest is just cut and paste from the reference guide.
> I just put in the ="<c:get select=$action/@expression/>"
> Any help would be great.
> <c:stringTokens string="<c:get select=$action/@expression/>"
> name="currentString" delimitedBy=" ">
> value: <c:get select="$currentString/@value"/>
> index: <c:get select="$currentString/@index"/>
> delimiter: <c:get select="$currentString/@delimiter"/>
> first: <c:get select="$currentString/@first"/>
> last: <c:get select="$currentString/@last"/>
> </c:stringTokens>
news:eufltj$7ft$1@build.eclipse.org...
> luck:-
> delimitedBy=" ">
>> </c:stringTokens>
