Home » Eclipse Projects » GEF » Contributing to GEF Context menu
Contributing to GEF Context menu [message #82079] Wed, 04 June 2003 17:19 Go to next message
Eclipse User
Originally posted by: schmerl+gef.cs.cmu.edu
I'm trying to work out how to use plugin extensions to add contributions to
the context menu that comes up in the GEF diagram. Is this possible? If so,
could someone direct me to the documentation to do it?
So far, I've tried the objectContribution extension, using edit parts as the
objectClass, and also the class of the editor that registers the context
menu, to no avail.
Any help much appreciated,
Bradley.
P.S. This is what I've tried so far:
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="myId"
objectClass="org.eclipse.gef.editparts.AbstractGraphicalEditPart ">
</objectContribution>
</extension>
<viewerContribution id="myId"
targetID="org.eclipse.gef.examples.logicdesigner.LogicEditor ">
</viewerContribution>
</extension>
Re: Contributing to GEF Context menu [message #82110 is a reply to message #82079] Wed, 04 June 2003 22:28 Go to previous messageGo to next message
Eclipse User
There is another step required in the code that created the MenuManager.
The logic editor does not register its menus for contribution, I don't
believe.
"Bradley Schmerl" <schmerl+gef@cs.cmu.edu> wrote in message
news:bblnps$nr3$1@rogue.oti.com...
to
so,
the
> menu, to no avail.
> Bradley.
> <objectContribution
> id="myId"
> </extension>
> </extension>
Re: Contributing to GEF Context menu [message #82264 is a reply to message #82110] Thu, 05 June 2003 09:37 Go to previous messageGo to next message
Eclipse User
That's right. The constructor for org.eclipse.gef.ContextMenuProvider only
allows an EditPartViewer as a parameter. I can't find out how to set the id
for the menu (which is private to MenuManager and only seems to be settable
through construction). Is there a way to set the ID?
Bradley.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bbm9s5$1sn$1@rogue.oti.com...
> believe.
> > Hi,
> to
> so,
> the
> > menu, to no avail.
> > Bradley.
> > <objectContribution
> > id="myId"
> > </extension>
> > </extension>
Re: Contributing to GEF Context menu [message #82526 is a reply to message #82264] Thu, 05 June 2003 22:48 Go to previous messageGo to next message
Eclipse User
You do not need to set the ID. I think this is only for submenus? Use:
IWorkbenchtPartSite#registerContextMenu (ID, menu, provider);
Hey, do you Randy Pausch? He was one of my professors.
news:bbnh38$b1$1@rogue.oti.com...
id
settable
> Bradley.
Re: Contributing to GEF Context menu [message #899605 is a reply to message #82526] Wed, 01 August 2012 10:46 Go to previous messageGo to next message
Karthikeyan Missing name is currently offline Karthikeyan Missing name
Member
Have you got solution. If so kindly post that code or kindly mail to triumph.karthikeyan@gmail.com. Myself need of that code.
Thanks & Regards,
Karthikeyan.B
[Updated on: Wed, 01 August 2012 10:47]
Report message to a moderator
Re: Contributing to GEF Context menu [message #899630 is a reply to message #899605] Wed, 01 August 2012 11:54 Go to previous messageGo to next message
Jan Krakora is currently offline Jan Krakora
in your GraphicalEditor implementation register the menu with the editor's site:
	protected void configureGraphicalViewer() {
		super.configureGraphicalViewer();
		final GraphicalViewer graphicalViewer = getGraphicalViewer();
		// Context menu
		ContextMenuProvider provider = new YourContextMenuProvider(graphicalViewer, getActionRegistry());
		graphicalViewer.setContextMenu(provider);
		getSite().registerContextMenu(provider, graphicalViewer);
in your context provider implementation you have to add standard action groups:
	public void buildContextMenu(IMenuManager manager) {
		GEFActionConstants.addStandardActionGroups(manager);
Then you can easily add menu contribution using as follows:
<extension
         point="org.eclipse.ui.menus">
      <menuContribution
            locationURI="popup:idOfYourEditor?after=org.eclipse.gef.group.save">
         <command
               commandId="org.eclipse.ui.file.save"
               style="push">
         </command>
      </menuContribution>
      <menuContribution
            locationURI="popup:idOfYourEditor?after=additions">
         <command
               commandId="someCommandId"
               style="push">
         </command>
      </menuContribution>
</extension>
Re: Contributing to GEF Context menu [message #899712 is a reply to message #899630] Thu, 02 August 2012 01:10 Go to previous messageGo to next message
Member
Thank you for your reply. Sorry myself new to this. Kindly clarify below doubts.
In buildContextmenu in mycontextProvider, how to add palette tools into that.
In plugin.xml
<command
style="push">
</command>
what commandId need to be given and from where. And how it is being used.
Note: My requirement is to bring Palette tools into the GEF editor on user mouse click, as like GMF and graphiti ie show in attached image. Kindly refer it. Is it possible?
Thanks & Regards,
Karthikeyan.B
[Updated on: Thu, 02 August 2012 02:45]
Re: Contributing to GEF Context menu [message #899755 is a reply to message #899712] Thu, 02 August 2012 04:41 Go to previous messageGo to next message
Wow, it looks nice, the tools are shown when right click on the editPart?
They did it, so it must be possible:) But I don't know how. You are free to look at the source code of the graphiti.
As of adding tools from the palette to the context menu, look at this
http://www.eclipse.org/forums/index.php/t/368734/
[Updated on: Thu, 02 August 2012 04:41]
Re: Contributing to GEF Context menu [message #899823 is a reply to message #899755] Thu, 02 August 2012 09:20 Go to previous messageGo to next message
Member
If you got any idea or code. Kindly help me in this.
Requirement: we can implement gmf or graphiti class in our GEF Plugin to achieve this functionality.
Thanks & Regards,
Karthikeyan.B
Re: Contributing to GEF Context menu [message #901153 is a reply to message #899823] Fri, 10 August 2012 02:38 Go to previous messageGo to next message
Member
It is done by slightly modifying the DiagramPopupBarEditPolicy in GMF. I got that image popup. Now myself need to show the menu on left click of icons in that popup. Can anyone tell me, how to create a menu as like context menu with custom icons in the mouse left click of popup bar icons.
index.php/fa/11127/0/
Thanks & Regards,
Karthikeyan.B
  • Attachment: untitled.JPG
    (Size: 12.30KB, Downloaded 213 times)
[Updated on: Fri, 10 August 2012 02:49]
Re: Contributing to GEF Context menu [message #902762 is a reply to message #901153] Mon, 20 August 2012 06:25 Go to previous messageGo to next message
Member
Finally i achieved the above concept using PromptForConnectionAndEndCommand in org.eclipse.gmf.runtime.diagram.ui.commands package. It has been altered corresponding to GEF and used.
Thanks & Regards,
Karthikeyan.B
Re: Contributing to GEF Context menu [message #902906 is a reply to message #899755] Tue, 21 August 2012 01:22 Go to previous message
Member
In my editor, I created tree edit part. In that modelChildren method, i override as following
getModelChildren()
List result = new ArrayList();
result.add(component1);
result.add(component2);
return result;
my problem is, when i add shapes in editor in following order
component2 - 1
component1 - 1
component2 - 2
component1 - 2
but in my tree view it exist as follows
component1 - 1
component1 - 2
component2 - 1
component2 - 2
Kindly suggest any solution for this.
Thanks & Regards,
Karthikeyan.B
Previous Topic:Background Image - Poof!
Next Topic:[Draw2D] How to create loop connection
Current Time: Sat May 18 20:46:30 EDT 2013
Powered by FUDForum. Page generated in 0.06289 seconds
