| Error occurred during initialization of VM [message #18225] |
Wed, 21 August 2002 23:54  |
Originally posted by: chinakapok.sina.com
Hello, I'm a newer to use the Eclipse platform.
After I create a new "Java" project and write a simple program.
When I run it, error occur as below,
_____________________________________________
"Error occurred during initialization of VM
java/lang/NoClassDefFoundError: java/lang/Object"
Below is my program
_______________________________________________
public class SimpleProgram {
System.out.println("This is a simple program.");
I don't known why?
Thanks in advance.
tiger
| Re: Error occurred during initialization of VM [message #18291 is a reply to message #18225] |
Fri, 23 August 2002 12:56   |
Originally posted by: ren.nospam.com
Dude,
I have got the same problem. Once you resolve it, could you let me too?
This is annoying..
Ren
> Below is my program
> public static void main(String[] args) {
> I don't known why?
> Thanks in advance.
> tiger
| Re: Error occurred during initialization of VM [message #19544 is a reply to message #18225] |
Tue, 27 August 2002 18:40   |
Originally posted by: Chang.Zu.com
Go to launch configuration, check ur bootstrap classes tab under Classpath.
Add rt.jar (The JRE) by clicking on Add external jars.
See if this works coz it worked for me.
tiger wrote:
> Hello, I\'m a newer to use the Eclipse platform.
> After I create a new \"Java\" project and write a simple program.
> \"Error occurred during initialization of VM
> java/lang/NoClassDefFoundError: java/lang/Object\"
> Below is my program
> System.out.println(\"This is a simple program.\");
> I don\'t known why?
> Thanks in advance.
> tiger
FUDForum. Page generated in 0.01894 seconds
