| mpiJava not building in eclipse - noob [message #819204] |
Mon, 12 March 2012 12:17  |
Rudolf Hoehler Messages: 1 Registered: March 2012 |
Junior Member |
Hey guys,
I'm rather new to Java, so please bare with me!
I have downloaded and installed mpiJava, and I can compile and run java code that imports mpi routines in a bash terminal using the javac and java commands.
In order to get this to work I had to set some environmental paths for bash.
CLASSPATH=$CLASSPATH:/mirror/mpiJava/lib/classes/
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/mirror/mpiJava/lib/
PATH=/mirror/mpich2/bin:$PATH
LD_LIBRARY_PATH=/mirror/mpich2/lib:$LD_LIBRARY_PATH
I cannot do the same in Eclipse.
Eclipse underlines import mpi.* with a red line. I then add an external class folder that points to the mpiJava classes folder, and the red lines go away. Now the IDE will allow me to build and run.
When I press play I get errors. I have edited the eclipse.ini file and made sure that eclipse uses the correct java vm. I don't get any errors when using the command line and emacs so I know at the very least the system is working.
The erros I get:
Quote:Exception in thread "main" java.lang.UnsatisfiedLinkError: no savesignals in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1681)
at java.lang.Runtime.loadLibrary0(Runtime.java:840)
at java.lang.System.loadLibrary(System.java:1047)
at mpi.MPI.<clinit>(MPI.java:46)
at Hello.main(Hello.java:21)
I work on Ubuntu 11.10 with eclipse downloaded from the Ubuntu Repo's.
Any help or pointer will greatly be appreciated.
Thanks for taking the time to help me out - you're time is really appreciated!
Rudolf
The code for what it is worth:
* Author of revised version: Franklyn Pinedo
* Adapted from Source Code in C of Tutorial/User's Guide for MPI by
* Peter Pacheco.
import java.util.*;
import java.lang.*;
import java.net.*;
import mpi.* ;
class Hello
static public void main(String[] args) throws MPIException
MPI.Init(args) ;
int my_rank = 0; // Rank of process
int source = 0; // Rank of sender
int dest = 0; // Rank of receiver
int tag=50; // Tag for messages
int myrank = MPI.COMM_WORLD.Rank() ;
int p = MPI.COMM_WORLD.Size() ;
if(myrank != 0) // is another node!
dest=0;
char[] message = null;
try
message = ( "Greetings from computer: " + InetAddress.getLocalHost().getHostName() ).toCharArray();
catch ( Exception error )
MPI.COMM_WORLD.Send( message, 0, message.length, MPI.CHAR,dest, tag );
else
{ // my_rank == 0
for ( source =1;source != p;source++)
char[] message = new char[60];
MPI.COMM_WORLD.Recv( message, 0, 60, MPI.CHAR, source, tag );
System.out.println( message );
MPI.Finalize();
[Updated on: Mon, 12 March 2012 12:18] Report message to a moderator
FUDForum. Page generated in 0.01655 seconds
