Home » Eclipse Projects » Web Tools Project (WTP) » Generate > XML File
Generate > XML File [message #124738] Fri, 22 July 2005 10:06 Go to next message
Keith Wells is currently offline Keith Wells
I am using the XHTML modular schemas to generate XHMTL files using WTP.
I have imported the XHTML schemas into a project in my workspace from this
zip file:
http://www.w3.org/TR/2004/WD-xhtml-modularization-20040218/x html-modularization.zip
Select and right click on the the file xhtml11.xsd. Select Generate > XML
File. In the New Wizard , accept the default File Name and select "Next".
I am seeing the error "A root element must be specified" at the top of the
page... In RAD 6.0.0.1 this scenario generates a new XML File successfully.
Is this a bug?
Configuration:
wtp-sdk-I20050722.zip with documented pre-reqs.
Re: Generate > XML File [message #124908 is a reply to message #124738] Fri, 22 July 2005 14:36 Go to previous messageGo to next message
Craig Salter is currently offline Craig Salter
> Is this a bug?
This sounds like a bug. Most likely we've hit some problems when
processing your schema and we think there's no root elements. Please open
a bug for this and attach your tests case. Thanks for your help!
Re: Generate > XML File [message #818961 is a reply to message #124738] Mon, 12 March 2012 06:16 Go to previous message
Anna Krajewska is currently offline Anna Krajewska
Was this bug opened/resolved? I have the same problem with my schema.
Anna
Previous Topic:May i ask a question related to the Eclipse Java EE IDE Indigo
Next Topic:CXF JAXWS will always default to Axis2
Current Time: Tue May 21 11:47:40 EDT 2013
Powered by FUDForum. Page generated in 0.07737 seconds
