Home » Eclipse Projects » Virgo » Where to download the virgo form tags sample?
Where to download the virgo form tags sample? [message #818328] Sun, 11 March 2012 08:26 Go to next message
Rice Yeh is currently offline Rice Yeh
There is a case study virgo form tags in chapter 6 in the virgo programmer guide. Where do I download the source code?
Rice
Re: Where to download the virgo form tags sample? [message #818412 is a reply to message #818328] Sun, 11 March 2012 11:38 Go to previous messageGo to next message
Just find the git://git.eclipse.org/gitroot/virgo/org.eclipse.virgo.sample-formtags.git. However, after checking out, I get the following error by following the instructions in the README.TXT file under the war folder. It complains that a file named default.xml does not exist in the vrigo-build/war folder.
/home/rice/workshops/osgi/org.eclipse.virgo.sample-formtags/war/formtags-war/build.xml:8: Cannot find /home/rice/workshops/osgi/org.eclipse.virgo.sample-formtags/war/formtags-war/../../virgo-build/war/default.xml imported from /home/rice/workshops/osgi/org.eclipse.virgo.sample-formtags/war/formtags-war/build.xml.
Rice
Re: Where to download the virgo form tags sample? [message #818905 is a reply to message #818412] Mon, 12 March 2012 05:04 Go to previous message
Glyn Normington is currently offline Glyn Normington
The formtags sample may have rotted a bit. Did you try building it with Ant? The git repository is meant to be built with Ant to produce a zip which the user grabs and builds with Maven. See here.
Previous Topic:Is it possible to use Apache Felix instead of Equinox as the OSGi platform for Virgo?
Next Topic:Virgo won't use Velocity 1.7.0, only 1.6.2
Current Time: Tue Jun 18 03:18:40 EDT 2013
Powered by FUDForum. Page generated in 0.01716 seconds
