Home » Newcomers » Newcomers » libxml2(compile and link libxml2)
libxml2 [message #818514] Sun, 11 March 2012 15:21 Go to next message
ak jax is currently offline ak jax
I try to use libxml2 in a C++ project, and I use Eclipse to edit and compile
Running this on the command line
xml2-config --cflags
gives
-I/usr/include/libxml2
xml2-config --libs
gives
-lxml2
In ordinary Makefile I should write:
CFLAGS=`xml2-config --cflags`
LIBS=`xml2-config --libs`
In the menu:
Project\settings\Tool Settings\GCC C++ Linker\Miscellaneous\Linker flags
I have enter -lxml2
Where shall I insert following line in eclipse
It seems that Eclipse cannot found the library
Is there something else I need to do?
[Updated on: Sun, 11 March 2012 15:45]
Report message to a moderator
Re: libxml2 [message #818760 is a reply to message #818514] Mon, 12 March 2012 00:34 Go to previous message
Russell Bateman is currently offline Russell Bateman
On 2012.03.11 13:21, Ake Jacksen wrote:
> I try to use libxml2 c++ project that I use Eclipse to edit and compile
> when running the line below on command line:
> I get
> to get the compilation flags and
> xml2-config --libs
> I get:
> -lxml2
> I an ordinary make file I should do following:
> Project\Settings\Tool Settings\GCC C++ linker\Miscellaneouslinker flags
> I have added
> -lxml2
> Where do I put
> Is it something else i need to do to get this working?
As the sticky posts at the top of this forum say, please ask your C/C++
questions in the Eclipse CDT forum.
Previous Topic:[SOLVED] Content/Code Assist Broken?
Next Topic:Eclipse RCP - How to show web browser preferences in preference dialog if it is not there
Current Time: Mon May 20 13:37:05 EDT 2013
Powered by FUDForum. Page generated in 0.01592 seconds
