Home » Eclipse Projects » BIRT » Serial Numbers(Serial Numbers)
Serial Numbers [message #817013] Fri, 09 March 2012 09:32 Go to next message
JP Missing name is currently offline JP Missing name
Hi All,
I would like to generate serial numbers without using running count as a computed column in BIRT 3.7.1. Is this possible to generated the sequence.
I have tried with the following script, but not possible.
var sr = 0;
for(var y=0; y<= Total.count(dataSetRow["RC"]); y++)
sr = y;
return sr;
Please suggest me.
Thanks.
JP
JP
Re: Serial Numbers [message #817277 is a reply to message #817013] Fri, 09 March 2012 16:55 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
JP,
Where do you have this code?
Jason
On 3/9/2012 9:32 AM, JP Mising name wrote:
> Hi All,
> var sr = 0;
> sr = y;
> return sr;
> Please suggest me.
> Thanks.
> JP
Jason Weathersby
BIRT Exchange
Re: Serial Numbers [message #817540 is a reply to message #817013] Sat, 10 March 2012 02:53 Go to previous messageGo to next message
Hi Jason,
Just i have try with this code, please give me correct code for generating sequence numbers.
JP.
JP
Re: Serial Numbers [message #817615 is a reply to message #817540] Sat, 10 March 2012 05:46 Go to previous message
Hi Joson,
I have done this using aggregation column with running count function.
JP
JP
Previous Topic:pdf emitter gives an "Internet Explorer cannot display the webpage" with IE 8 and https
Next Topic:Birt fails on report with strings
Current Time: Sat May 25 12:22:51 EDT 2013
Powered by FUDForum. Page generated in 0.01668 seconds
