Home » Newcomers » Newcomers » Retrieve the saved location of the android-sdk from eclipse
Retrieve the saved location of the android-sdk from eclipse [message #817037] Fri, 09 March 2012 10:02 Go to next message
Ashton Cummings is currently offline Ashton Cummings
Is there a way to get the saved location of the "android-sdk" within eclipse?
If you go to window -> preferences -> android. There is a text field containing the location of the android-sdk. Is there a way to query eclipse for that value in an ANT script or by other means?
Sorry if this is the wrong area to post, but i do not see a section for Android or a section for general questions about eclipse.
Re: Retrieve the saved location of the android-sdk from eclipse [message #817471 is a reply to message #817037] Sat, 10 March 2012 00:20 Go to previous message
David Wegener is currently offline David Wegener
> eclipse?
You don't see a section for Android because Android is a Google product.
You should visit their forums for Android support.
Previous Topic:Cannot unzip the Eclipse for Java EE on Windows 7
Next Topic:Eclipse is not starting
Current Time: Fri May 24 03:41:03 EDT 2013
Powered by FUDForum. Page generated in 0.01577 seconds
