| Re: can you update the derby core plugin version? [message #817230 is a reply to message #816994] |
Fri, 09 March 2012 15:26  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Currently the derby plugin is used only for the sample db. I see no
reason why the new one will not work.
Jason
On 3/9/2012 8:55 AM, Aaron Titus wrote:
> Jason Weathersby wrote on Wed, 07 March 2012 13:20
>> Does it fail when you delete the 10.5 version? You may also want to
>> remove the sampledb plugin.
>> org.eclipse.birt.report.data.oda.sampledb_version
>> Jason
> Well, I was nervous to just remove it and see what happens, that is why
> I made the post here. Since the plugin name is different from the
> default derby one, I want to know if BIRT has some dependency on these
> and if I remove them, will BIRT stop functioning properly?
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01640 seconds
