Home » Eclipse Projects » Apricot » Building Apricot from the Eclipse Git repo
Building Apricot from the Eclipse Git repo [message #754821] Fri, 04 November 2011 09:31 Go to next message
Chris Frost is currently offline Chris Frost
I realise it's early days but I just tried to build Apricot and it failed. Are there any docs somewhere.
Checked it out from Eclipse git and ran 'mvn clean package'
Failed with,
[INFO] Eclipse ECR Core Event Tests ...................... SUCCESS [2.099s]
[INFO] Eclipse ECR Core IO Test .......................... FAILURE [1.408s]
[INFO] Eclipse ECR Core Query Test ....................... SKIPPED
[INFO] Eclipse ECR Core Schema Test ...................... SKIPPED
Thanks, and welcome to Eclipse.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Building Apricot from the Eclipse Git repo [message #757302 is a reply to message #754821] Thu, 17 November 2011 10:39 Go to previous messageGo to next message
Marwane Kalam-Alami is currently offline Marwane Kalam-Alami
I just successfully built Apricot by using the ecr-installer project (found in /build/product/ecr-installer). It is used by running the org.eclipse.ecr.build.Main class:
 * Usage:
 * <p>
 * <code>Main [-r repository] [-p profiles] profile target</code>
 * <p>
 * Example:
 * <p>
 * <code>Main -r (url) -p default target/ecr.zip</pre>
 * <p>
 * If the target path ends with .zip then the product will be zipped.
 * @author <a href="mailto:bs@nuxeo.com">Bogdan Stefanescu</a>
Re: Building Apricot from the Eclipse Git repo [message #816341 is a reply to message #757302] Thu, 08 March 2012 13:35 Go to previous messageGo to next message
Matt Butler is currently offline Matt Butler
AFAICT "Building Apricot" using the ecr-installer really just assembles Apricot from some pre-built parts. The maven builds seems to work now.
Re: Building Apricot from the Eclipse Git repo [message #816871 is a reply to message #816341] Fri, 09 March 2012 06:22 Go to previous message
Yeah, I have it building as well now. Now if only there were some docs.
Previous Topic:Missing com.sun.ws.rs.ext.RuntimeDelegateImpl class
Current Time: Mon May 27 22:33:52 EDT 2013
Powered by FUDForum. Page generated in 0.01567 seconds
