| Hosted repository with virgo tomcat server 3.0.2 [message #780328] |
Tue, 17 January 2012 11:03  |
jc perron Messages: 3 Registered: January 2012 |
Junior Member |
Did someone manage to configure an hosted repository with virgo 3.0.2 ? I made it work only with virgo 2.1.1.
In virgo 2.1.1 I simply modify the file config/org.eclipse.virgo.apps.repository.properties to add my reposiroties and restart the server. Here is my file :
hosted-omni.type=watched
hosted-omni.watchDirectory=repository/hosted-omni
hosted-maven.type=watched
hosted-maven.watchDirectory=repository/hosted-maven
In virgo 3.0.2 with the same configuration when I restart the server there is nothing at the adresse : myserver:8080/org.eclipse.virgo.apps.repository/hosted-maven
| Re: Hosted repository with virgo tomcat server 3.0.2 [message #782879 is a reply to message #782823] |
Tue, 24 January 2012 11:30   |
Anton Kolmakov Messages: 14 Registered: January 2012 |
Junior Member |
I had downloaded Virgo 2.1.1 and added new hosted repository to org.eclipse.virgo.apps.repository.properties file:
hosted.type=watched
hosted.watchDirectory=repository/hosted
After that I have started the server and performed a simple test that sends HTTP GET request with URI "http://localhost:9080/org.eclipse.virgo.apps.repository/hosted":
0:0:0:0:0:0:0:1 - - [24/Jan/2012:18:08:48 +0200] "GET /org.eclipse.virgo.apps.repository/hosted HTTP/1.1" 200 101
The server successfully processed the request and returned some XML response.
Virgo 3.0.2 does not pass the test:
0:0:0:0:0:0:0:1 - - [24/Jan/2012:18:09:36 +0200] "GET /org.eclipse.virgo.apps.repository/hosted HTTP/1.1" 404 952
And when another server tries to access a remote repository hosted on Virgo 3.0.2, it fails because of the 404 error. With 2.1.1 version of Virgo everything works.
[Updated on: Tue, 24 January 2012 11:32] Report message to a moderator
| Re: Hosted repository with virgo tomcat server 3.0.2 [message #1009517 is a reply to message #816684] |
Fri, 15 February 2013 04:09  |
daniel marthaler Messages: 11 Registered: April 2012 Location: Zürich |
Junior Member |
Missing name Missing name wrote on Fri, 09 March 2012 07:18hi:
You should put the org.eclipse.virgo.apps.repository.properties into the org.eclipse.virgo.apps.repository_3.0.2.par file, and it should work.
Hi Glyn
Would it be possible to amend the user guide to reflect that important configuration step?
Thanks Dani
FUDForum. Page generated in 0.05699 seconds
