Home » Eclipse Projects » Target Management » SSH Public Key Access Connection Failure(Infinitely prompting for private key passphrase)
SSH Public Key Access Connection Failure [message #816427] Thu, 08 March 2012 16:14
Tim Butler is currently offline Tim Butler
I'm unsuccessfully attempting to connect with SSH public key as the only authentication method, using a private DSA key towards an embedded Linux target. This combination works fine outside of Eclipse. However, when I attempt to connect w/ RSE, I'm continuously prompted for the private key passphrase, which I've confirmed is correct. The log indicates nothing more than the Informational message about beginning the connection.
Any ideas about how to proceed? I saw bug 357354 which appears to describe a somewhat similar problem, and hasn't been resolved.
Version: Indigo Service Release 1
Build id: 20110916-0149
RSE Version: 3.3.1.R33
Host: Mac OSX 10.7
Tim
Previous Topic:Extending Shell Process
Next Topic:Release 3.3.2 not availabl via update site eclipse.org/tm/
Current Time: Sat May 25 23:31:08 EDT 2013
Powered by FUDForum. Page generated in 0.01929 seconds
