Home » Eclipse Projects » GEF » JBPM problem depends on Draw2D code?
JBPM problem depends on Draw2D code? [message #815571] Wed, 07 March 2012 15:38
pbartosz   is currently offline pbartosz
I'm using JBPM 4.3 and problem occurs when moving transition bendpoint outside viewport. The scrollbar doesn't show and transition is cut. If I move a node outside viewport, scrollbar shows.
Edit: I have changed PolylineConnection layout manager to my own and set ConnectionLayer layout manager and it works.
[Updated on: Fri, 09 March 2012 17:18]
Report message to a moderator
Previous Topic:Imprecise of the GEF (draw2d)
Next Topic:Yfiles Layout With Gef
Current Time: Wed May 22 13:20:22 EDT 2013
Powered by FUDForum. Page generated in 0.06904 seconds
