Home » Eclipse Projects » Dali » NPE in Indigo SR2 when adding JPA facet
NPE in Indigo SR2 when adding JPA facet [message #814538] Tue, 06 March 2012 10:17 Go to next message
David Vree is currently offline David Vree
Member
I've been running Indigo SR1 with Dali (for JPA support) for some time without issue.
Today I'm trying a fresh install of Indigo SR2 from scratch. When I go to add the JPA facet to my Java project, I keep getting a NullPointerException as follows:
Any help on this is welcome as our team has really grown to depend on the Dali tools for JPA!
eclipse.buildId=M20120208-0800
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product org.eclipse.epp.package.jee.product
Error
Tue Mar 06 10:11:15 EST 2012
Failed while installing JPA 2.0.
at org.eclipse.jpt.common.core.internal.resource.ModuleResourceLocator.getDefaultResourceLocation(ModuleResourceLocator.java:34)
at org.eclipse.jpt.jpa.core.internal.facet.JpaFacetInstallDelegate.defaultResourceLocation(JpaFacetInstallDelegate.java:141)
at org.eclipse.jpt.jpa.core.internal.facet.JpaFacetInstallDelegate.createPersistenceXml(JpaFacetInstallDelegate.java:111)
at org.eclipse.jpt.jpa.core.internal.facet.JpaFacetInstallDelegate.createProjectXml(JpaFacetInstallDelegate.java:101)
at org.eclipse.jpt.jpa.core.internal.facet.JpaFacetInstallDelegate.execute_(JpaFacetInstallDelegate.java:62)
at org.eclipse.jpt.jpa.core.internal.facet.JpaFacetActionDelegate.execute(JpaFacetActionDelegate.java:34)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject.callDelegate(FacetedProject.java:1477)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject.modifyInternal(FacetedProject.java:441)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject.mergeChangesInternal(FacetedProject.java:1181)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject.access$2(FacetedProject.java:1117)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject$5.run(FacetedProject.java:1099)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProject.mergeChanges(FacetedProject.java:1109)
at org.eclipse.wst.common.project.facet.core.internal.FacetedProjectWorkingCopy.commitChanges(FacetedProjectWorkingCopy.java:2020)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsPropertyPage$4.run(FacetsPropertyPage.java:232)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsPropertyPage$5.run(FacetsPropertyPage.java:246)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Re: NPE in Indigo SR2 when adding JPA facet [message #814694 is a reply to message #814538] Tue, 06 March 2012 14:35 Go to previous messageGo to next message
Paul Fullbright is currently offline Paul Fullbright
I'm not seeing this behavior. Can you give more details for how it occurs, preferably in a new bug?
Re: NPE in Indigo SR2 when adding JPA facet [message #814695 is a reply to message #814538] Tue, 06 March 2012 14:37 Go to previous messageGo to next message
(forum barf)
[Updated on: Tue, 06 March 2012 14:39]
Report message to a moderator
Re: NPE in Indigo SR2 when adding JPA facet [message #814706 is a reply to message #814694] Tue, 06 March 2012 14:50 Go to previous messageGo to next message
Member
Paul Fullbright wrote on Tue, 06 March 2012 14:35
Will do.
Re: NPE in Indigo SR2 when adding JPA facet [message #814814 is a reply to message #814538] Tue, 06 March 2012 18:06 Go to previous message
Neil Hauge is currently offline Neil Hauge
Not to distract from the bug you are probably entering, but did you use the "Configure" menu "Convert to JPA Project...", or some other mechanism? I assume your existing projects are importing fine?
This seems to be working for me as well. Happy to hear your team is experiencing the benefits of the Dali tooling. Hopefully we can find a quick resolution to the problem you are seeing.
Neil
Previous Topic:Eclipse JPA problem on a named query that doesn't have a problem
Next Topic:JPA Diagram Editor and JEE INDIGO error.
Current Time: Wed May 29 01:24:19 EDT 2013
Powered by FUDForum. Page generated in 0.20680 seconds
