Home » Eclipse Projects » BIRT » Jboss Stream closed Exception on ODS/ODT reports generation
Jboss Stream closed Exception on ODS/ODT reports generation [message #814327] Tue, 06 March 2012 05:10 Go to next message
Tony M is currently offline Tony M
Hello every one,
I have a problem when i generate ODS/ODT (it could be for the other open document formats as well) reports using birt API, Jboss is shown below.
a small note that the report is rendered properly, i am getting the proper output, it's just the exception and so far i have not succeeded to find a solution for it.
Any help would be appreciated
Thanks a lot
Tony
11:47:16,209 SEVERE [AbstractOdfEmitter] Stream closed
java.io.IOException: Stream closed
at java.util.zip.ZipOutputStream.ensureOpen(ZipOutputStream.java:70)
at java.util.zip.ZipOutputStream.closeEntry(ZipOutputStream.java:189)
at org.eclipse.birt.report.engine.odf.pkg.Package.writeManifest(Package.java:188)
at org.eclipse.birt.report.engine.odf.pkg.Package.close(Package.java:120)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.save(AbstractOdfEmitter.java:166)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.end(AbstractOdfEmitter.java:143)
at org.eclipse.birt.report.engine.emitter.ods.OdsEmitter.end(OdsEmitter.java:552)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:694)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at com.smartechlb.oikos.reporting.service.BirtEngineService.render(BirtEngineService.java:1047)
at com.smartechlb.oikos.reporting.web.BirtEngineController.renderReport(BirtEngineController.java:73)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:471)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:40
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at com.smartechlb.oikos.reporting.utils.JsonpCallbackFilter.doFilter(JsonpCallbackFilter.java:65)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:235)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:190)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:662)
Re: Jboss Stream closed Exception on ODS/ODT reports generation [message #814702 is a reply to message #814327] Tue, 06 March 2012 14:42 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
This is a known issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372671
Jason
On 3/6/2012 5:10 AM, Tony Mising name wrote:
> Hello every one,
> Thanks a lot
> Tony
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Jason Weathersby
BIRT Exchange
Previous Topic:how to create dependent component in the same report
Next Topic:is there functionallity in birt to go to client side with out report regeneration
Current Time: Sat May 25 10:18:55 EDT 2013
Powered by FUDForum. Page generated in 0.04259 seconds
