| How to use a properties file, internal to the Eclipse project and the jar. [message #814582] |
Tue, 06 March 2012 11:17  |
DonCamp Messages: 6 Registered: January 2011 |
Junior Member |
I can't figure out how to use a Properties file which is inside the
Eclipse project, and which I want to include in the jar.
The properties file - ErrorCodes.properties - is in the src folder
\Project\src. The main method is in a source file in the
src/java/com.mycompany.err.customcodes folder.
I've tried the following 3 statements, but in all cases ErrorCodeStream
is populated with null.
InputStream ErrorCodeStream =
getClass().getClassLoader().getResourceAsStream("/src/ErrorCodes.properties"
getClass().getClassLoader().getResourceAsStream("src/ErrorCodes.properties");
getClass().getClassLoader().getResourceAsStream("ErrorCodes.properties");
| Re: How to use a properties file, internal to the Eclipse project and the jar. [message #814648 is a reply to message #814621] |
Tue, 06 March 2012 13:06   |
Junior Member |
Equivalent problem, using ResourceBundle:
Any of the following errors occur:
Can't find bundle for base name src.java.resources.ErrorCodes
Can't find bundle for base name java.resources.ErrorCodes
Can't find bundle for base name /java.resources.ErrorCodes
Can't find bundle for base name /src/java/resources/ErrorCodes
, depending on what is used for the path, e.g.
ResourceBundle rb = ResourceBundle.getBundle("java.resources.ErrorCodes")
Per the instructions at the link
http://www.javahotchocolate.com/topics/resbundle.html,
the ErrorCode.properties file has been placed in src/java/resources
(that's what Eclipse generated, after creating the resources package).
On 3/6/2012 12:17 PM, DonCamp wrote:
> Looks detailed enough, thanks Russell.
> On 3/6/2012 11:47 AM, Russell Bateman wrote:
>> On 3/6/2012 9:17 AM, DonCamp wrote:
>>> Hi,
>>> [snip]
>> Here's a simple article to get you started:
| Re: How to use a properties file, internal to the Eclipse project and the jar. [message #814649 is a reply to message #814648] |
Tue, 06 March 2012 13:11  |
Junior Member |
Never mind, got it. Had to take the path out completely, using instead:
ResourceBundle rb = ResourceBundle.getBundle("ErrorCodes");
>>>> Hi,
>>>> [snip]
FUDForum. Page generated in 0.01666 seconds
