| Exception occurred during code generation for wsdl [message #814168] |
Tue, 06 March 2012 00:31 |
Anisha Jayadevan Messages: 2 Registered: February 2012 |
Junior Member |
I am using the Eclipse tutorial to create a Bottom-up Web Service and to generate a client to consume the service(Can't post the link since this is only my second message to the forum!).
I use Eclipse IDE for Java EE Developers, have downloaded Axis2-1.6.1 and use Tomcat v5.5.
After creating and testing the service, I try generating the client as per the tutorial and encounter this error:
Exception occurred during code generation for WSDL : null
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.jst.ws.axis2.core.utils.Axis2CoreUtils.getSourceFolder(Axis2CoreUtils.java:245)
at org.eclipse.jst.ws.axis2.consumption.core.command.Axis2ClientCodegenCommand.execute(Axis2ClientCodegenCommand.java:138)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFragmentEngine.moveForwardToNextStop(CommandFragmentEngine.java:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleCommandEngineManager.runForwardToNextStop(SimpleCommandEngineManager.java:264)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageManager.performFinish(WizardPageManager.java:262)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizard.performFinish(DynamicWizard.java:382)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:257)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:277)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Please help?
The WSDL is attached as a file.
Attachment: TestBPL.wsdl
(Size: 3.35KB, Downloaded 84 times)
FUDForum. Page generated in 0.01557 seconds
