Home » Eclipse Projects » Hudson » login to hudson 2.0.0 failing on my client(After registration, login works for a very short time, then fails)
login to hudson 2.0.0 failing on my client [message #813980] Mon, 05 March 2012 17:46
Dave Field is currently offline Dave Field
Our Hudson admin setup a login for me. After registering, my login works fine for several minutes from both IE and Chrome on my Win7 64bit machine. But, then, it stops working. I notice that if I enter an incorrect username and/or password, I get the error, "Invalid login information. Please try again." But, if I enter username and password correctly, it just flashes once going back to empty username and password input fields with no error at all. So, I suspect that it is authenticating, but maybe there is some kind of access control problem. Our Hudson admin doesn't know what to check and, apparently, my machine is the only one that has this problem because when the admin tries login with my login, it works for him. Any clues on what might be the problem?
Previous Topic:Hudon + Maven3+ release plugin.....Error
Next Topic:SvnTag Plugin issue Hudson v. 2.2.0
Current Time: Sat May 25 07:52:40 EDT 2013
Powered by FUDForum. Page generated in 0.01606 seconds
