| QueryException occurs on an expression that is using getAllowingNull() on an aggregate attribute. [message #813661] |
Mon, 05 March 2012 10:18  |
Dragomir Zoranovic Messages: 7 Registered: February 2012 |
Junior Member |
I have query defined as follows:
ReadAllQuery query = new ReadAllQuery(User.class);
ExpressionBuilder eb = new ExpressionBuilder(User.class);
query.addOrdering(eb.getAllowingNull("aggregateUser").get("aggregateName"));
Attribute aggregateUser is defined as aggregate object of the object User.This query throws following QueryException:
Exception Description: An outer join (getAllowingNull or anyOfAllowingNone) is only valid for OneToOne, OneToMany, ManyToMany, AggregateCollection and DirectCollection Mappings, and cannot be used for the mapping [org.eclipse.persistence.mappings.AggregateObjectMapping].
Should I prevent using getAllowingNull() on agreggate attibutes? Or is there any another solution?
[Updated on: Mon, 05 March 2012 10:23] Report message to a moderator
FUDForum. Page generated in 0.01594 seconds
