| Basic Eclipse Strings [message #810636] |
Thu, 01 March 2012 06:04  |
Sebastian Hä älä Messages: 11 Registered: October 2011 |
Junior Member |
I am looking for a way to translate basic Strings from Eclipse/BIRT like "Data Set", "Data Qube" or "Variables". Data Set and Data Qube are translated already (for german) but I think they are wrong! In the Outline view Variables isn't translated (German) for me!
I tryed to search these but couldn't find them.
| Re: Basic Eclipse Strings [message #810969 is a reply to message #810636] |
Thu, 01 March 2012 14:01   |
Denis Roy Messages: 231 Registered: July 2009 Location: Ottawa, Ontario, Canada |
Babel doesn't support searching for an English string and translating it, but that does sound like a great feature to add. Can you open a feature request against Technology > Babel > Server ?
Denis Roy
Eclipse Webmaster -- webmasterAeclipse,org
| Re: Basic Eclipse Strings [message #811002 is a reply to message #810969] |
Thu, 01 March 2012 15:06   |
If you have the MySQL data dump, you can use this SQL statement to generate completely usable URLs for English strings:
select distinct CONCAT("http://babel.eclipse.org/babel/translate.php?project=", f.project_id, "&version=", f.version, "&file=", f.name, "&string=", s.name) AS URL from files as f inner join strings as s on s.file_id = f.file_id where s.value IN("Data Cube", "Data Set") and s.is_active = 1;
Denis Roy
| Re: Basic Eclipse Strings [message #811345 is a reply to message #811085] |
Fri, 02 March 2012 03:14  |
Junior Member |
Thank you for your responses! I filed a feature request.
Also I found some of the string here:
babel.eclipse.org/babel/translate.php?project=birt&version=3.7.0&file=org.eclipse.birt.report.designer.ui.cubebuilder/org/eclipse/birt/report/designer/ui/cubebuilder/nls/messages.properties
EDIT: I would have postet it as a link but they won't let me post links so just type a http:/ / infront
[Updated on: Fri, 02 March 2012 03:15] Report message to a moderator
FUDForum. Page generated in 0.05781 seconds
