Home » Eclipse Projects » Eclipse Process Manager (Stardust) » The audit trail contains no model Exception/Message(The audit trail contains no model Exception/Message)
The audit trail contains no model Exception/Message [message #800117] Thu, 16 February 2012 13:07 Go to next message
Vikram Kodak is currently offline Vikram Kodak
Member
The application has published to Tomcat ok, however when logging into the application, I receive the message 'CWP01006 - The audit trail contains no model'.
[Updated on: Thu, 16 February 2012 13:17]
Report message to a moderator
Re: The audit trail contains no model Message [message #800121 is a reply to message #800117] Thu, 16 February 2012 13:09 Go to previous messageGo to next message
Member
Hello
Process execution requires prior deployment of the process model to the audit trail database, Please refer the documentation section within eclipse(RAD) help 'Deployment of the Infinity Model'
Infinity Documentation > Developer Handbooks > Rapid Application Development > Deployment
[Updated on: Thu, 16 February 2012 13:21]
Re: The audit trail contains no model Message [message #810905 is a reply to message #800121] Thu, 01 March 2012 12:07 Go to previous message
Jan Hendrik Scheufen is currently offline Jan Hendrik Scheufen
Member
By default the Stardust web portal does not allow you to login if no process model has been deployed.
This setting can be changed via a context parameter in the web.xml
  <context-param>
  	<param-name>carnot.login.MODEL_REQUIRED</param-name>
  	<param-value>true</param-value>
  </context-param>
Previous Topic:Stardust not starting up. Oracle log showing [ OCRUTL][3280]
Next Topic:Model loading fails with exception
Current Time: Tue May 21 14:41:10 EDT 2013
Powered by FUDForum. Page generated in 0.01485 seconds
