| Virgo Nano + p2 + profile [message #810441] |
Thu, 01 March 2012 00:05  |
Mixa Alekseev Messages: 9 Registered: February 2011 |
Junior Member |
How to run my eclipse-product uses the e4 (juno) environment?
I created a p2 update site and try to add it:
1) drop in pickup - which leads to a conflict of versions
2) I tried to add it through the mechanism of p2 - result 1)
3) I tried to create a profile p2 command: 'provinstall my.feature 1.0 myprofile' -
GoGo StringIndexOutOfBoundsException: String index out of range: -1
Maybe I did not understand the meaning of p2-profile?
Outside virgo product works (the part that does not use the spring)
Sorry for my bad English.
| Re: Virgo Nano + p2 + profile [message #810680 is a reply to message #810519] |
Thu, 01 March 2012 07:19  |
Junior Member |
I install org.eclipse.core.runtime_3.8.0.v20110920-2042 (download.eclipse.org/releases/juno/201202030900)
osgi> provinstall org.eclipse.pde.core 3.8.0.v20120118-1658
Installation complete for org.eclipse.pde.core 3.8.0.v20120118-1658
osgi> confapply
gogo: IllegalStateException: The System Bundle was updated. The framework must be restarted to finalize the configuration change
I restart virgo - result:
!ENTRY org.eclipse.equinox.cm 4 0 2012-03-01 20:53:52.124
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.cm_1.0.300.v20101204 [42]" could not be resolved. Reason: Missing Constraint: Import-Package: org.osgi.service.cm; version="[1.3.0,1.4.0)"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1327)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1311)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.equinox.ds 4 0 2012-03-01 20:53:52.203
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.ds_1.3.0.v20110124-0830 [45]" could not be resolved. Reason: Missing Constraint: Import-Package: org.osgi.service.component; version="[1.1.0,1.2.0)"
Basically I need to satisfy dependency "org.eclipse.osgi_3.8.0.v20120123-1419"
FUDForum. Page generated in 0.02037 seconds
