| Subpackages URI problem [message #590140] |
Mon, 19 July 2010 14:43  |
Toñi Reina Messages: 197 Registered: July 2009 |
--------------010303000601030005000706
Hi all,
I'm writing a M2T transformation using a metamodel composed of various
packages, as it is shown in the screenshot I have attached. The root
class of the metamodel is included in the diagram package.
Each package has a different URI, in such a way that the root package
has as uri "http:\\org.name.root" and the uri of the diagram package is
"http:\\org.name.root.diagram". The problem is that when I load the
metamodel, MOFScript can not find the URI http:\\org.name.root.diagram,
and as a consequence, can not use the root class, nor other class,
because classes are in second level packages.
I suppose there is a problem with subpackages uris, Can someone tell
me how to register subpackages uri's or, to make Mofscript understand
the uri?
Thanks in advance.
To
| Re: Subpackages URI problem [message #810584 is a reply to message #590140] |
Thu, 01 March 2012 04:36  |
Atenea Missing name Messages: 4 Registered: July 2009 |
Junior Member |
Hi all,
Hi Toñi.
I have the same problem that Toñi Reina, I can't read information in other packages, I can read only in the first one.
Toñi did you solve the problen?
Did Someone solve the problem?
Thanks in advance
FUDForum. Page generated in 0.01620 seconds
