Home » Eclipse Projects » Dali » Eclipse JPA problem on a named query that doesn't have a problem
Eclipse JPA problem on a named query that doesn't have a problem [message #804855] Wed, 22 February 2012 23:24 Go to next message
David Vree is currently offline David Vree
Member
As of today, I am getting the following JPA error in Eclipse Indigo SR1:
"The identification variable 'name' is not defined in the FROM clause."
on the following class that I haven't touched in weeks and that compiles and runs without issue:
@XmlRootElement(name = "namespace")
@XmlType(name = "namespace",
propOrder = { "name", "description" })
@NamedQueries({ @NamedQuery(name = "NamespaceImpl.findUniqueByName", query = "SELECT n FROM NamespaceImpl n WHERE name = ?1") })
@Entity
@Table(name = "namespc")
public class NamespaceImpl {
private String name;
private String description;
public NamespaceImpl(final String name, final String description) {
this.name = name;
this.description = description;
@XmlElement
@Column(nullable = false, unique = true, length = 20)
public String getName() {
return name;
public void setName(final String name) {
this.name = name;
@XmlElement
@Column(length = 80)
public String getDescription() {
return description;
public void setDescription(final String description) {
public NamespaceImpl() {
super();
Something must have changed recently, but I don't know what. The project is built with Maven and has the JPA facet. The JPA Platform for the project is set to "Generic 2.0" and the implementation has been set to "disable library configuration".
Re: Eclipse JPA problem on a named query that doesn't have a problem [message #805245 is a reply to message #804855] Thu, 23 February 2012 09:41 Go to previous messageGo to next message
Neil Hauge is currently offline Neil Hauge
David,
I'm not sure if the query changed or perhaps your Eclipse Dali version changed, but from looking at it, I would think your query should be:
@NamedQueries({ @NamedQuery(name = "NamespaceImpl.findUniqueByName", query = "SELECT n FROM NamespaceImpl n WHERE n.name = ?1") })
Note the reference to "name" is now qualified by the identification variable 'n'. This should resolve the issue.
Neil
Re: Eclipse JPA problem on a named query that doesn't have a problem [message #808791 is a reply to message #805245] Tue, 28 February 2012 01:24 Go to previous message
Member
Indeed it did fix the problem. Thank you very much. As the named query hasn't changed, it must have been a Dali update to Indigo that trigger the validation error. I didn't know where clause variables needed qualification when selecting from just one table.
One other thing to note, when I fixed it and saved the Java file, for whatever reason, it did not trigger a revalidation. I had to explicitly trigger one by hand. Not sure what is up with that....
Previous Topic:Unable to generate JAXB classes
Next Topic:NPE in Indigo SR2 when adding JPA facet
Current Time: Wed May 29 01:24:43 EDT 2013
Powered by FUDForum. Page generated in 0.01574 seconds
