Home » Eclipse Projects » Buckminster » Is there any way to share Advisor Nodes between CQuery's
Is there any way to share Advisor Nodes between CQuery's [message #793009] Tue, 07 February 2012 12:02 Go to next message
Matthew Webber is currently offline Matthew Webber
The topic says it all. We have a number of different products that share various components. The shared components live in various (Git) respoitories. Each product has a CQuery to materialize it, and each of those CQuery's has a number of advisor nodes that say what branch of various repositories to look in.
There are some parts in common between the Advisor nodes in differnt CQuerys. We'd like to have some common Advisor Nodes somewhere that we can share / inherit /re-use.
Looking at the BuckyBook, I don't think this is possible, even with clever use of properties, but does anyone have any suggestions?
Matthew
Re: Is there any way to share Advisor Nodes between CQuery's [message #793341 is a reply to message #793009] Tue, 07 February 2012 21:44 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
I know people have done clever things by having a servlet compose cquery
documents (as well as other buckminster artifacts).
This way you get central management, and people only have to have
Eclipse + Buckminster installed, then know the URL to the cquery (that
gets produced dynamically).
- henrik
> Matthew
Re: Is there any way to share Advisor Nodes between CQuery's [message #808151 is a reply to message #793341] Mon, 27 February 2012 08:11 Go to previous message
Jakob Braeuchi is currently offline Jakob Braeuchi
Member
hi,
we have a "Tagging Tool", a proprietary frontend for SVN. The TaggingTool modifies CQueries when branching or tagging; it replaces SelectionCriteria in AdvisorNodes and fixes the RMAP-Urls and other things. It prevents a mixing of Trunk,Branches and Tags.
jakob
Previous Topic:Build eclipse project from ANT script
Next Topic:Build Project
Current Time: Sun May 19 15:37:39 EDT 2013
Powered by FUDForum. Page generated in 0.01633 seconds
