| Hello World Swing Client not showing up? [message #805829] |
Fri, 24 February 2012 02:31  |
Kai Wähner Messages: 4 Registered: February 2012 |
Junior Member |
Hello.
I just downloaded and started the current release of Eclipse Scout. I use a Macbook Air with Lion and Java 6.
I tried to get started with the Hello World tutorial.
Server and SWT client work fine, but the Swing client does not show up. It starts and is running. No error messages or exceptions. Nevertheless, the client does not show up anywhere... There is also no seconds Eclipse / RCP starting as it is when I start a SWT client.
The console output of the client is:
2012-02-24 08:15:52.358 java[598:407] [Java CocoaComponent compatibility mode]: Enabled
2012-02-24 08:15:52.359 java[598:407] [Java CocoaComponent compatibility mode]: Setting timeout for SWT to 0.100000
The server does not have any console output.
Any guess? Do you need more details?
Kai
FUDForum. Page generated in 0.05180 seconds
