| BIRT bar chart report shutting down weblogic server [message #804544] |
Wed, 22 February 2012 14:01  |
Shaju J Messages: 5 Registered: January 2012 |
Junior Member |
We have a BIRT report with bar chart in it running fine in multiple app server environments. In one of our server, (Solaris - Weblogic 10.3), if I try to bring up this report, it kills the application server. We have narrowed down this to a variable set in the environment where we are starting Weblogic.
DISPLAY=localhost:10.0.
If we remove this env variable, everything seems to be fine.
The only error message I can see is
"X connection to localhost:10.0 broken (explicit kill or server shutdown)."
This is a product which will be installed at multiple client locations and I may not be able to tell them to take out the DISPLAY variable. Is there any setting in BIRT which I can use to fix this issue?
Any help is much appreciated!
FUDForum. Page generated in 0.01811 seconds
